Just updated to 2020.05.22.2254, and BTN is now working on Spectrum. Thank you, thank you, thank you.
I've been periodically having this issue with MSNBC using Comcast/Xfinity as my provider. I'm currently on 2020.05.25.2131
Submited diagnostics logs as 99b38674-ad14-4b63-b1c5-48236a564628
For the past several days, I have been unable to get ESPN network channels to authorize in TVE. In the logs they are listed as ‘notAuthorized’.
- My cable provider is AT&T U-Verse;
- I can login to ESPN.com using my cable account info;
- I have disabled my Pi-Hole while I deleted and added back my AT&T account info to the Channels TVE sources.
Logs have been submitted as 5c6ff1ce-bea7-4be6-a767-70e2c4a730b3.
Thank you for your assistance.
Awesome — thank you!
I am having the same problem. So, where do I get v2020.09.30.1607? My install says I have v2020.09.14.2100 and when I click on "Check for Update" it says I am up to date.
Click and hold the “check for update” button to get the pre-release version.
