Nucleus HTPC
@Morris_Altman The esc key exits the htpc. I will attempt to add an exit icon somewhere that will not cause an issue with the menu spacing.
V1.3.1 released with the Exit button added. The fix for updater is in this release. It did not get pushed in the last release.
Thank you Bobby,
Working :-}
Morris
V1.3.2 is to address some nav issues with the sports page and to test the update installer on build 1.3.1.
Do you think the red stands out too much for the exit button?
Not for me. Red fine. I wonder how other feel.
I will probably mute the red down some. Maybe a darker overlay when it isn't mouse over or highlighted.
I just upgraded to 1.3.2. Still fine. I think it would work the same as the other tabs are colored. The good thing is that you have it in the same place in all menues. Consistency makes it easy to find.
Never mind. I'm reporting something you've already fixed.
All good. I messed up the links for the installer when I was changing hard coded colors to DynamicResources, I removed the Click methods in the links and they were basically dead links at that point. That has been fixed in the latest release.
I find that red button disturbing. I suggest matching the look of the tab buttons, and lowering the height to match that row too (or just making it part of that group).
I've upgraded and the changing time on the slider is AWESOME! Thanks.
v1.3.3 Released
  • Cosmetic Changes: Exit link on full screen view uses standard nav colors and some missed theme colors fix.
  • Remote Control Focus Trap Fix: Sports sorting pills menu would lose focus with rc nav.
The exit is much less glaring and being consistently located makes it easy to fine.
The right side seems like a good place for it. That's where I always look for a close button. Thanks.
I just installed Nucleus htpc and it would be great if I could enter a channel number using a keyboard and the guide would jump to that number. but overall great work!!! thanks.
edit: please also add av1 support for recordings. thanks.
Adding the channel number input for the guide and also tuning by numbers in the player is easy enough. Adding direct stream playback is a bit more of a challenge as the raw path is not consistent and drives would need to be mapped with proper permissions to allow playback. That's a more than I want to tackle right now.
Then please just add channel number input for now. thanks.
I really hate to do this to you but I have a user who cant watch tv until this fix is out. I am happy to donate to expedite this and have it done today. thanks.
I will be out as soon as I can. Probably Sunday, maybe tomorrow.
