I'd suggest you try to spin-up Watchtower, using the Docker Compose and env vars from this thread:
Let's see if that will deploy, which will also update your running containers. After that, if you could post a screenshot of your Portainer-Containers page, that might be helpful.
For some containers it may take a while for Portainer to finish.
If you switch away from the Stacks view while it's deploying one, it will fail.
You can check for errors in Portainer if it couldn't install the stack (Events and Notifications).
You can also view your containers in Portainer.
Giving up. Just tried it directly on the server using Chrome and it's more of the same. I think it's getting close, but the error while creating mount source path '/host_mnt/Users/olivetin/data': mkdir /host_mnt/Users/olivetin: permission denied is causing it to fail. No idea where that's coming from or how to correct it. Maybe I'll set the user account as admin and try it one last time.
I realize you've given up, but I typically still try to get to the bottom of issues -- just in case they come up again.
Though I'm not a daily Mac user, I do have a Mac-Mini-M2 for testing and as an ARM component to my build cluster. It's been a while since I've spun-up OliveTin on it though, so thought I'd make sure no issues have crept in.
Nothing to report though, OliveTin deployed on the M2 as expected with these env vars:
It did remind me of an old issue with the types of File Sharing available on the Mac, which have changed several times over the years since Docker has been available. If you have a chance, could you check your Docker Desktop settings and see which File Sharing you're using?
Hmm. Aside from a line about using "Rosetta for x86_64/amd emulation" (because I'm on an M1 Mac mini, not Intel) my settings look the same as yours, but I do have "Enable background SBOM indexing" enabled. You may want to try that?
@Curtis Not having the Rosetta emulation option showing -- given you said your Mac Mini has an Apple chip, makes me wonder about your Docker Desktop installation. Is it possible you somehow installed the amd64 version of Docker Desktop (via Rosetta) rather than the arm64 version? Not sure how to check that, but maybe somebody else knows if it's possible first, and how to check second.
You mentioned having problems with Docker Desktops updates as well, no?
In the /Applications folder, select Docker Desktop. Then go to File → Get Info (or just press Command-I) and you'll get a window that reveals what type of app it is:
New bnhf/olivetin:latest (aka bnhf/olivetin:2024.10.01) pushed today with support for creating a Channel Collection based on the channels in one or more sources. This is courtesy of some more fine work from @mjitkop -- so, many thanks to him!
The OliveTin WebUI doesn't allow blank fields -- so it must always be specified currently. I'll do some more work next time around to have a default dummy entry, that can be stripped in the script. But, for now, an entry is always required for collection_name, which of course can be the same as the source name.
Believe me, @mjitkop, I noticed, and do care. My wife and I are nursing our critically ill doggie, and DVR stuff has taken a back seat lately. I'll give your Channel Collection tool a whirl when I find a chance.
I saw it and it's another great addition.
Unfortunately I have yet to get OliveTin fully operational on my end. Just haven't had time to do the troubleshooting lately.
@mjitkop BTW, I used your new "Create Channel Collection from Sources" script today (via the OliveTin Action of course ) to update my primary viewing collection. Something I've been meaning to do for a while, and your script made it super-duper easy. Very cool and useful tool -- love it!
New bnhf/olivetin:latest (aka bnhf/olivetin:2024.10.02) pushed this morning. This includes several nice updates to the new Create Channel Collection from Sources script by @mjitkop.
