Olivetin may be up?
I think I have this cleaned up. Let me know if you see anything
Checking your OliveTin-for-Channels installation...
(extended_check=false)
OliveTin Container Version 2025.09.21
OliveTin Docker Compose Version 2025.08.25
Checking that your selected Channels DVR server (192.168.1.62:8089) is reachable by URL:
HTTP Status: 200 indicates success...
100  1276  100  1276    0     0   623k      0 --:--:-- --:--:-- --:--:--  623k
HTTP Status: 200
Effective URL: http://192.168.1.62:8089/
Checking that your selected Channels DVR server's data files (/mnt/192.168.1.62-8089) are accessible:
Folders with the names Database, Images, Imports, Logs, Movies, Streaming and TV should be visible...
total 8
drwxr-xr-x 2 root root 4096 Sep 21 15:36 .
drwxr-xr-x 1 root root 4096 Sep 21 16:59 ..
Docker reports your current DVR_SHARE setting as...
/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/volumes/channels-dvr/_data
If the listed folders are NOT visible, AND you have your Channels DVR and Docker on the same system:
Channels reports this path as...
D:\DVR
When using WSL with a Linux distro and Docker Desktop, it's recommended to use...
/mnt/d/DVR
Checking that your selected Channels DVR server's log files (/mnt/192.168.1.62-8089_logs) are accessible:
Folders with the names data and latest should be visible...
total 8
drwxr-xr-x 2 root root 4096 Sep 21 15:37 .
Docker reports your current LOGS_SHARE setting as...
/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/volumes/channels-dvr-logs/_data
C:\ProgramData\ChannelsDVR
/mnt/c/ProgramData/ChannelsDVR
Checking if your Portainer token is working on ports 9000 and/or 9443:
Portainer http response on port 9000 reports version
Portainer Environment ID for local is
Portainer https response on port 9443 reports version
Here's a list of your current OliveTin-related settings:
HOSTNAME=olivetin
CHANNELS_DVR=192.168.1.62:8089
CHANNELS_DVR_ALTERNATES=
CHANNELS_CLIENTS=
ALERT_SMTP_SERVER=
ALERT_EMAIL_FROM=[Redacted]@
ALERT_EMAIL_PASS=[Redacted]
ALERT_EMAIL_TO=[Redacted]@
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
PORTAINER_TOKEN=[Redacted]
PORTAINER_HOST=192.168.1.42
PORTAINER_PORT=9443
PORTAINER_ENV=2
Here's the contents of /etc/resolv.conf from inside the container:
# Generated by Docker Engine.
# This file can be edited; Docker Engine will not make further changes once it
# has been modified.
nameserver 127.0.0.11
search jim_office
options ndots:0
# Based on host file: '/etc/resolv.conf' (internal resolver)
# ExtServers: [10.0.3.1]
# Overrides: [nameservers search]
# Option ndots from: internal
Here's the contents of /etc/hosts from inside the container:
127.0.0.1	localhost
::1	localhost ip6-localhost ip6-loopback
fe00::0	ip6-localnet
ff00::0	ip6-mcastprefix
ff02::1	ip6-allnodes
ff02::2	ip6-allrouters
172.29.0.2	olivetin
A post was merged into an existing topic: Project One-Click: All-in-One Installations of Docker Extensions and CDVR Custom Channels
