Hi,
"On later" is not working for me in the Channels Fire TV app. Is anyone else having the same issue? The screen loads & stays blank, nothing displayed (other than the title) and no options to "fine tune" etc.
Thanks.
Hi,
Thanks.
There’s a bug, it should be showing a modal about how to use it.
Please use the fine tune button to add some preferred items to help On Later work better for you. Then it will show.
Ok thanks.
Ive also noticed that when I add additional sources (so currently have terrestrial, satellite & also online streaming services), the "on later" is intermittent to load. When I have only 1 or 2 sources, it doesn't seem to be such an issue. Is this something to do with load times? As in I have soo much content that the "on later" times out?
On my FireTV Max 4K device (Gen 2), there is no "Fine Tuning" button displayed anywhere. In fact, it's a completely blank screen except for the title, "On Later" at the top of the screen.
Although I don't use it or like how it works, it ("Fine Tuning" button) is available in the DVR web admin UI.
Had the same problem.....see this thread....
Thanks for the info.
February 2022? It would be beneficial if the UI wouldnt display menu items for app features that havent been implemented. As it stands, it's a poor user experience.
It works fine on my Firestick 4k Max Gen2 devices. I haven't done any fine tuning of the On Later preferences on the web server and it has been working fine for more than a year on all my Android and FireTV devices.
