Optimum Provider - TVE source won't authenticate
Since you said you followed all the troubleshooting steps in TVE Troubleshooting tips
You must have done step 15.
From my email: Web UI Troubleshooting log files - 1fc31a5d-368f-4681-aadd-9d597bbbdd6e (all green checks).
No - same errors. Just tried it again.
2025/07/25 17:31:44.579686 [TVE] Auth starting for Cablevision as dec3169
2025/07/25 17:31:44.715666 action=requestor err=Get "https://sp.auth.adobe.com/adobe-services/config/ABC?noflash=true": tls: failed to verify certificate: x509: certificate has expired or is not yet valid: current time 2025-07-25T17:31:44-05:00 is after 2025-06-15T23:59:59Z
2025/07/25 17:31:44.715741 [TVE] action=auth mvpd=Cablevision requestor=ABC
2025/07/25 17:31:44.963210 [TVE] action=version product=Chrome/132.0.6834.83 jsVersion=13.2.152.27 protocol=1.3 revision=@03d59cf5ecf1d8444838ff9a1e96231304d4ff9c
2025/07/25 17:31:44.963576 [TVE] action=page_ready chromeVersion=132
2025/07/25 17:31:44.963699 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=Cablevision&requestor_id=ABC&no_iframe=true&domain_name=adobe.com&reg_code=&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2025/07/25 17:31:44.964797 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2025/07/25 17:31:45.228010 [TVE] action=error_response type=Document error=net::ERR_CERT_DATE_INVALID url=https://sp.auth.adobe.com/adobe-services/authenticate/saml ip=54.68.29.35
2025/07/25 17:31:45.302022 [TVE] action=wait_for_page
2025/07/25 17:31:50.350233 [TVE] action=page_ready
2025/07/25 17:31:50.350269 [TVE] action=wait_for_page done=true reason=page_ready
2025/07/25 17:31:50.350283 [TVE] action=wait_for_auth timeout=12s
2025/07/25 17:31:50.350298 [TVE] action=fill_form u=dec3169
2025/07/25 17:31:50.353319 [TVE] action=fill_form state=done err=&runtime.ExceptionDetails{ExceptionID:1, Text:"Uncaught (in promise)", LineNumber:0, ColumnNumber:0, ScriptID:"", URL:"", StackTrace:(*runtime.StackTrace)(nil), Exception:(*runtime.RemoteObject)(0xc0007f1050), ExecutionContextID:0, ExceptionMetaData:easyjson.RawMessage(nil)}
2025/07/25 17:31:50.353356 [TVE] action=screenshot
2025/07/25 17:31:50.370770 [TVE] action=screenshot file=tve_error_screenshot.png size=37264
2025/07/25 17:31:50.370870 [TVE] action=capture_html
2025/07/25 17:31:50.372739 [TVE] action=capture_html file=tve_error_screenshot.html size=149170
2025/07/25 17:31:50.372868 [TVE] action=capture_html
2025/07/25 17:31:50.374530 [TVE] action=capture_html file=tve_error_screenshot.html size=149170
2025/07/25 17:31:50.379573 [TVE] action=script_error err=no login form found
2025/07/25 17:31:50.459147 [TVE] Auth failed for Cablevision: no login form found
Reminder - while I'm doing all this I am watching a channel from my 2nd source using KlowdTV. In case that matters - it is working fine.
Seems like a bad dns cache somewhere in your stack.
You could compare i.e dig <hostname>
Which host should I dig - sp.auth.adobe.com? I tried that last night and it looked ok.
I will say I looked at my dns last night and I don't have caching turned on (couldn't remember because I've run it so long). I changed the dns serial number, did an upgrade on Ubuntu just in case, and even updated to today's pre-release - and rebooted. Still the same results and the same errors in the log.
I checked my syslogs on the host running CDVR (and dns secondary) and had one time in June where all my dns forwarders (like 8.8.8.8, 1.1.1.1, and 4.2.2.1) timed out trying to reach channels-dvr.s3.amazonaws.com but that was during a brief cable internet outage. That's expected.
I made sure to turn my vpn proxy (in another docker container) off and verified my IP with whatsmyip.org to ensure it was my ISP and not somewhere else. I disabled adblocker in the settings - not just for the page I was on. I can't think of anything I missed.
Could it be an issue with Optimum? Maybe their cert really is expired and they didn't notice because most people using TVE are using it on the web (especially probably in my area). I want to know because I've been looking at other TV providers that will work with CDVR and are cheaper than Optimum's cable. I'd hate to switch and have them not work as well. I have to keep Optimum's Internet though - it is the only 1gb in my area until the fiber company hits my area.
I can always send more logs if you need me to. I am running CDVR 2025.07.26.0227 in docker on Ubuntu 24.04.2 with 128GB RAM, a decent GPU, 12th Gen Intel(R) Core(TM) i9-12900K with 24 cores, and 21TB free disk space. The system is on ethernet directly connected to my 6E mesh wifi router master, then to the cable modem (personal, and provisioned by Optimum - not the Optimum trash that never gave me over 700mbps). Speedtest just gave me 939.28mbps down and 53mbps up (they only do 50mbps up). I know system resources aren't an issue.
Thank you for looking at this. Judging by your profile I don't think there is anyone better than you to help. I really appreciate it.
If you view the certificate for the server Channels DVR is hitting, you'll see it's expired.
https://54.68.29.35/
You need to get DNS to resolve the hostname to a different server IP address.
Try ping sp.auth.adobe.com to see what IP that hostname resolves to
From my Windows PC
ping -4 -n 1 sp.auth.adobe.com
Pinging ethos501-prod-or2-k8s-p2-0-a1ad666b2de4356f.elb.us-west-2.amazonaws.com [44.229.68.88] with 32 bytes of data:
From inside my Channels DVR container on my NAS
# ping -4 -c1 sp.auth.adobe.com
PING sp.auth.adobe.com (44.225.76.132): 56 data bytes
Those servers certificates are not expired.
Using my Windows PC
Network Inspector in EDGE shows
Request URL https://sp.auth.adobe.com/
Request Method GET
Status Code 200 OK
Remote Address 44.229.68.88:443
Referrer Policy strict-origin-when-cross-origin
Network Inspector in BRAVE shows
Request Method GET
Status Code 200 OK
Remote Address 44.225.76.132:443
Network Inspector in FIREFOX shows
method GET
scheme https
host sp.auth.adobe.com
filename /
Status 304
Version HTTP/2
Transferred 1.14 kB (26 B size)
DNS Resolution System
This is the solution thanks to chDVRuser and tmm1. They both got me looking into name resolution and I found the modified /etc/hosts file in the container thanks to them. Solution was to remove the hardcoded entries for the host sp.auth..adobe.com.
So between chDVRuser and tmm1 I was able to get enough clues to fix this. Apparently some time in the past I must've edited the /etc/hosts file in the container - unless something does that automatically? I don't recall ever getting into the container to do that, but the file looked like this:
127.0.0.1	localhost
127.0.1.1	cartman
#198.54.122.135	mail.privateemail.com
# The following lines are desirable for IPv6 capable hosts
::1     ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
# Added by Docker Desktop
# To allow the same kube context to work on the host and the container:
127.0.0.1	kubernetes.docker.internal
# End of section
54.68.29.35	sp.auth.adobe.com
44.239.120.244	sp.auth.adobe.com
Note the sp.auth.adobe.com entries at the bottom. The one that starts with 54 was the expired one.
I deleted those 2 lines, saved it, and exited the container. Then I successfully added the source and got 140 channels. I bet when the one cert expired I started losing channels, but is it common for providers to use 2 separate IPs and certs for their TVE range? Seems odd, but possible I guess.
I don't know who to mark for the solution since you both helped me. Aman, if you want to mark one of the posts as a solution that's fine. I appreciate the help, and now I know more than I thought I wanted to about the internals of CDVR :slight_smile:
BTW - sorry for any typos. My laptop is 11 years old and keys are starting to stick or not work. Guess I have to remove 5000 screws and clean the keyboard.
Adobe maintains many servers around the world and most likely uses load balancing and your DNS Server will choose the closest available server. So you will see the IP address for the host changing all the time. Same with any large company, like Google for instance. That's why trying to maintain a hosts file "is so 1970's".
Make sure you're not using the flag in your docker run command or docker compose statement
https://docs.docker.com/reference/cli/docker/container/run/#add-host
good call, but I don't have in my yaml.
compose yaml
https://docs.docker.com/reference/compose-file/services/#extra_hosts
I don't know about your docker setup, but on mine (Synology NAS), when I create a container, it copies my host OS /etc/hosts contents into the container /etc/hosts file.
It did at one point, but I don't have the adobe lines in my host /etc/hosts. That doesn't mean I didn't at one time though. Maybe I had an issue at one time with Optimum, but I don't remember ever having one - it just worked when I initially set it up. I have so much crap in my head from years of working with computers (I've been running Linux since 1992). I remember old passwords from the late '80s, my childhood phone number/address/zip, and I visited London with my wife 20 years after being stationed near there in the USAF and drove from Heathrow to a hotel I'd never seen but knew where it was - without a GPS or map. I remember a lot of stupid stuff but forget names - no more room in my brain I guess.
I probably had the adobe hosts in there for some reason but I'll never remember it.
