Hey Is anyone having issues with Philo in channels tonight? I am getting an error on every channel
I updated on the server and it still happened. I then removed and tried to add Philo back and it said no login page found. Is anyone else having this issue? I sent a log..but not sure if it made it. I am at a loss.
Philo working fine for me.
Philo is working great for me. Only problem I had recently was AMC channel blacked out for a couple of days, otherwise I don't recall any problems at all for more than a year. Getting it signed in and activated for Channels TVE can be somewhat difficult.
If you access your ChannelsDVR server through a browser and go to “Support”/“Troubleshooting” does everything report ok? I had problems with TVE a little while back and it turned out my ISP’s “protection” was causing things on the network to get blocked.
I ended up figuring out that an old Malware prevention app was causing it. Problem solved and all green checks on the troubleshooting list once I did that. Thanks everyone.
Oh man!\Hat when that happens.
Philo is one of the most stable TVE sources.
I had a problem with Reelz but later found that i had to update DNS on Synology.
