I have an issue I just can not seem to fix and I need help. I’m not sure if I have a HDHomeRun issue or a Channels Plus issue. What happens is everything is working fantastic then out of the blue the picture and audio freezes for 3 to 6 seconds. It will then typically pixelate and pickup where it left off sometimes audio seems to speed up for a few seconds and then 10 to 12 seconds later everything is fine. When it happens I watch the signal quality from HDHR on my iPad and everything looks normal. (Typically 100%) Nothing shows in the log either. If I remove the HDHR and system by plugging the same antenna feed directly into the TV it always works normally. I have reached out to SiliconDust Support and sent them the Diagnostics. I mentioned that the only thing I found on the HDHR forum was one person said the same thing happened to them when they upgraded to the same Firmware I have. HDHR Support said that it was doubtful that the FW was the issue. The only other thing they mentioned was that the HDHR was possibly getting overloaded with too much signal and they had me remove the amp. (it is still off as this antenna can be used with or without it. Passive & Active). The antenna guy was kind enough to replace the antenna with a new one (same model as that is all he uses in this area and even replace the entire coax cable run) I then added the LTE Filter hoping that would help but it did not. Last I heard from Support was 10 days ago asking for me to resend the Diagnostics Info which I did. Anyone out at there have any ideas? I really love this new system since killing my satellite TV with this one exception. Any help would be really appreciated. I posted this in the SiliconDust forum as well as I really can’t figure this out. Thanks!
My System:
DINOVA Boss Mix Antenna Model: 144282 with LTE Filtering - Professionally Installed
HD HomeRun Connect 4K HDHR5-4K Firmware 20210624
SiliconDust LPF-608M LTE Filter
Client: Nvidia Shield TV Pro - Hardwired
UHF Broadcast 8 miles away, no hills or obstructions
Virtual Channel 5.1 KSTPDT
Frequency 497.000 MHz
Program Number 3
Modulation Lock 8vsb
Signal Strength 100%
Signal Quality 100%
Symbol Quality 100%
Streaming Rate 10.654 Mbps
If only one stream, It always chooses Tuner 2 by default if that means anything.
Mostly we only use one stream but it happens with one or more streams as well.
Nothing I can see in the logs when it happens
Channels Plus DVR using TV Everywhere
Server: Synology DS920+ (That is the only App on it currently - CPU & Resources are never high)
Everything Hardwired gigabyte Ethernet
Thanks in advance for the help!
