Change that to the port number you want (you have an IP address there)
Since you're running it in the host network (--network=host), it won't display port mapping.
If you want it to run in the bridge network and use port mapping you have to drop the --network=host and --env=PLEX_PORT and include the port mapping you want.
You also have a lot of unnecessary statements in your docker run command.
Can we fix it via a software update? This sucks.
