Seems better for sure. Not 100% there but it's a lot better. It does release the CPU when it's done. It seems to check the scheduler and rerun every every ten minutes but it only takes 5 minutes to run, at least from the logs.
2025-02-17T14:04:37.781255573Z [DEBUG - PLEX] Processing Channels from 2025-02-17_epg.xml...
2025-02-17T14:04:39.732979352Z [DEBUG - PLEX] Processing Channels from 2025-02-18_epg.xml...
2025-02-17T14:04:41.462078286Z [DEBUG - PLEX] Processing Channels from 2025-02-19_epg.xml...
2025-02-17T14:04:43.143950266Z [DEBUG - PLEX] Processing Channels from 2025-02-20_epg.xml...
2025-02-17T14:04:44.980010121Z [DEBUG - PLEX] Processing Channels from 2025-02-21_epg.xml...
2025-02-17T14:04:46.714604076Z [DEBUG - PLEX] Processing Channels from 2025-02-22_epg.xml...
2025-02-17T14:04:48.330967501Z [DEBUG - PLEX] Processing Channels from 2025-02-23_epg.xml...
2025-02-17T14:04:49.864227021Z [DEBUG - PLEX] Processing Programs from 2025-02-17_epg.xml...
2025-02-17T14:04:56.513680598Z [DEBUG - PLEX] Processing Programs from 2025-02-18_epg.xml...
2025-02-17T14:05:02.943133769Z [DEBUG - PLEX] Processing Programs from 2025-02-19_epg.xml...
2025-02-17T14:05:10.645793388Z [DEBUG - PLEX] Processing Programs from 2025-02-20_epg.xml...
2025-02-17T14:05:18.104506087Z [DEBUG - PLEX] Processing Programs from 2025-02-21_epg.xml...
2025-02-17T14:05:24.449471840Z [DEBUG - PLEX] Processing Programs from 2025-02-22_epg.xml...
2025-02-17T14:05:30.421398685Z [DEBUG - PLEX] Processing Programs from 2025-02-23_epg.xml...
2025-02-17T14:05:35.969662697Z [DEBUG - PLEX] EPG FIle Created Elapsed time: 58.24 seconds.
2025-02-17T14:05:40.882833893Z [DEBUG - PLEX] Compressed EPG FIle Created Elapsed time: 4.91 seconds.
2025-02-17T14:05:40.891282044Z [DEBUG - PLEX] EPG Call Complete
2025-02-17T14:05:40.893130884Z [INFO - PLEX] EPG Scheduler Complete
2025-02-17T14:15:41.759769144Z [INFO - PLEX] Running EPG Scheduler for plex
2025-02-17T14:15:41.759959365Z [DEBUG - PLEX] Running EPG Call
2025-02-17T14:15:41.777391776Z [INFO - PLEX] Reading channel id list cache for all geo locations
2025-02-17T14:15:41.778613009Z [DEBUG - PLEX] Number of channels 615
2025-02-17T14:15:41.779107006Z [DEBUG - PLEX] EPG Pass 3
2025-02-17T14:15:41.779135561Z [NOTIFICATION - PLEX] Collect data for 2025-02-17
2025-02-17T14:15:41.779308634Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-17
2025-02-17T14:15:41.779373467Z [NOTIFICATION - PLEX] Collect data for 2025-02-18
2025-02-17T14:15:41.779529577Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-18
2025-02-17T14:15:41.779627632Z [NOTIFICATION - PLEX] Collect data for 2025-02-19
2025-02-17T14:15:41.779803465Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-19
2025-02-17T14:15:41.779854557Z [NOTIFICATION - PLEX] Collect data for 2025-02-20
2025-02-17T14:15:41.780006648Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-20
2025-02-17T14:15:41.780049537Z [NOTIFICATION - PLEX] Collect data for 2025-02-21
2025-02-17T14:15:41.780219851Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-21
2025-02-17T14:15:41.780261221Z [NOTIFICATION - PLEX] Collect data for 2025-02-22
2025-02-17T14:15:41.780439442Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-22
2025-02-17T14:15:41.780459998Z [NOTIFICATION - PLEX] Collect data for 2025-02-23
2025-02-17T14:15:41.780640311Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-23
2025-02-17T14:15:41.835111178Z [DEBUG - PLEX] Processing Channels from 2025-02-17_epg.xml...
2025-02-17T14:15:43.729256986Z [DEBUG - PLEX] Processing Channels from 2025-02-18_epg.xml...
2025-02-17T14:15:45.431661204Z [DEBUG - PLEX] Processing Channels from 2025-02-19_epg.xml...
2025-02-17T14:15:47.276215246Z [DEBUG - PLEX] Processing Channels from 2025-02-20_epg.xml...
2025-02-17T14:15:49.031069566Z [DEBUG - PLEX] Processing Channels from 2025-02-21_epg.xml...
2025-02-17T14:15:50.742635598Z [DEBUG - PLEX] Processing Channels from 2025-02-22_epg.xml...
2025-02-17T14:15:52.331456132Z [DEBUG - PLEX] Processing Channels from 2025-02-23_epg.xml...
2025-02-17T14:15:53.827618387Z [DEBUG - PLEX] Processing Programs from 2025-02-17_epg.xml...
2025-02-17T14:16:00.493097883Z [DEBUG - PLEX] Processing Programs from 2025-02-18_epg.xml...
2025-02-17T14:16:06.942158889Z [DEBUG - PLEX] Processing Programs from 2025-02-19_epg.xml...
2025-02-17T14:16:13.406507786Z [DEBUG - PLEX] Processing Programs from 2025-02-20_epg.xml...
2025-02-17T14:16:21.983443039Z [DEBUG - PLEX] Processing Programs from 2025-02-21_epg.xml...
2025-02-17T14:16:28.343407258Z [DEBUG - PLEX] Processing Programs from 2025-02-22_epg.xml...
2025-02-17T14:16:34.437515570Z [DEBUG - PLEX] Processing Programs from 2025-02-23_epg.xml...
2025-02-17T14:16:40.031681608Z [DEBUG - PLEX] EPG FIle Created Elapsed time: 58.25 seconds.
2025-02-17T14:16:44.963720967Z [DEBUG - PLEX] Compressed EPG FIle Created Elapsed time: 4.93 seconds.
2025-02-17T14:16:44.973914867Z [DEBUG - PLEX] EPG Call Complete
2025-02-17T14:16:44.975299803Z [INFO - PLEX] EPG Scheduler Complete
2025-02-17T14:16:44.975503579Z [INFO - PLEX] Checking scheduler thread
2025-02-17T14:26:45.844105183Z [INFO - PLEX] Running EPG Scheduler for plex
2025-02-17T14:26:45.844290590Z [DEBUG - PLEX] Running EPG Call
2025-02-17T14:26:45.860148344Z [INFO - PLEX] Reading channel id list cache for all geo locations
2025-02-17T14:26:45.861339651Z [DEBUG - PLEX] Number of channels 615
2025-02-17T14:26:45.861861574Z [DEBUG - PLEX] EPG Pass 0
2025-02-17T14:26:45.861917981Z [INFO - PLEX] Update Today's EPG data
2025-02-17T14:27:28.059186901Z [NOTIFICATION - PLEX] 2025-02-17 Station API Calls completed - Count 615: Elapsed time: 42.20 seconds.
2025-02-17T14:27:37.321156026Z [NOTIFICATION - PLEX] 2025-02-17 MediaContainer XML completed 615: Elapsed time: 9.26 seconds.
2025-02-17T14:27:39.743282624Z [DEBUG - PLEX] Number Stations identified: 615
2025-02-17T14:27:39.743376975Z [DEBUG - PLEX] Number Programs identified: 18870
2025-02-17T14:31:40.072912645Z [DEBUG - PLEX] Generate EPG Style completed: Elapsed time: 240.40 seconds.
2025-02-17T14:31:53.545964245Z [NOTIFICATION - PLEX] Collect data for 2025-02-17
2025-02-17T14:31:53.546082170Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-17
2025-02-17T14:31:53.546215392Z [NOTIFICATION - PLEX] Collect data for 2025-02-18
2025-02-17T14:31:53.546389150Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-18
2025-02-17T14:31:53.546442964Z [NOTIFICATION - PLEX] Collect data for 2025-02-19
2025-02-17T14:31:53.546653500Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-19
2025-02-17T14:31:53.546747648Z [NOTIFICATION - PLEX] Collect data for 2025-02-20
2025-02-17T14:31:53.546927869Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-20
2025-02-17T14:31:53.546964405Z [NOTIFICATION - PLEX] Collect data for 2025-02-21
2025-02-17T14:31:53.547093349Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-21
2025-02-17T14:31:53.547151941Z [NOTIFICATION - PLEX] Collect data for 2025-02-22
2025-02-17T14:31:53.547315700Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-22
2025-02-17T14:31:53.547367162Z [NOTIFICATION - PLEX] Collect data for 2025-02-23
2025-02-17T14:31:53.547523791Z [NOTIFICATION - PLEX] Using Saved Data for 2025-02-23
2025-02-17T14:31:53.602646341Z [DEBUG - PLEX] Processing Channels from 2025-02-17_epg.xml...
2025-02-17T14:31:57.165231144Z [DEBUG - PLEX] Processing Channels from 2025-02-18_epg.xml...
2025-02-17T14:31:58.996836218Z [DEBUG - PLEX] Processing Channels from 2025-02-19_epg.xml...
2025-02-17T14:32:00.748092675Z [DEBUG - PLEX] Processing Channels from 2025-02-20_epg.xml...
2025-02-17T14:32:02.469114225Z [DEBUG - PLEX] Processing Channels from 2025-02-21_epg.xml...
2025-02-17T14:32:04.312065118Z [DEBUG - PLEX] Processing Channels from 2025-02-22_epg.xml...
2025-02-17T14:32:06.005002026Z [DEBUG - PLEX] Processing Channels from 2025-02-23_epg.xml...
2025-02-17T14:32:07.405294177Z [DEBUG - PLEX] Processing Programs from 2025-02-17_epg.xml...
2025-02-17T14:32:14.126310991Z [DEBUG - PLEX] Processing Programs from 2025-02-18_epg.xml...
2025-02-17T14:32:20.596707977Z [DEBUG - PLEX] Processing Programs from 2025-02-19_epg.xml...
2025-02-17T14:32:29.229511763Z [DEBUG - PLEX] Processing Programs from 2025-02-20_epg.xml...
2025-02-17T14:32:35.737870276Z [DEBUG - PLEX] Processing Programs from 2025-02-21_epg.xml...
2025-02-17T14:32:42.110675104Z [DEBUG - PLEX] Processing Programs from 2025-02-22_epg.xml...
2025-02-17T14:32:48.167221969Z [DEBUG - PLEX] Processing Programs from 2025-02-23_epg.xml...
2025-02-17T14:32:53.874768072Z [DEBUG - PLEX] EPG FIle Created Elapsed time: 60.33 seconds.
2025-02-17T14:32:58.815262742Z [DEBUG - PLEX] Compressed EPG FIle Created Elapsed time: 4.94 seconds.
2025-02-17T14:32:58.839811091Z [DEBUG - PLEX] EPG Call Complete
2025-02-17T14:32:58.841116453Z [INFO - PLEX] EPG Scheduler Complete
2025-02-17T14:32:58.841657191Z [INFO - PLEX] Checking scheduler thread
