Problem solved. It turned out to be a timing problem on Windows startup. If I delay the startup of Docker for a minute after Windows starts, all works well.
Not sure how often the Channels clients update their guide info from the server.
This. To make sure you’re getting a fresh set of data force quitting the app and launching it again is the only way I know of.
On Android TV I clear it from recents so it refetches the guide data.
If you are using an intermediate source, here's is an example:
9:00 You retrieve data. (Data was issued at 3:02)
9:01 Your source updates data from Pluto. (Data was issued at 6:02)
9:02 Pluto updates it's data.
The data you just picked up at 9:00 was released by Pluto at 3:02, giving you a 6 hour delay.
If you are getting data direct from Pluto every hour, your maximum delay is one hour, with an average delay of 30 minutes.
Are any of these methods getting data "direct from Pluto" though? I was under the impression they're all using the same underlying, intermediate source, which sometimes has delays of its own. (i.mjh.nz)
I don't understand what you're saying in your example.
Here's what I use.
Pluto for Channels docker container grabs Pluto EPG every three hours beginning at 2 AM each day.
Channels DVR using Pluto for Channels as an m3u source updates m3u and xmltv every three hours beginning at 2:24 AM each day.
That's incorrect. The pluto docker talks to pluto directly and has nothing to do with that domain.
OK, my apologies! Thanks for the clarification. I was confusing the Pluto docker with the other one for Samsung TV+. And I'm not sure about the one for Stirr.
Anyway, back to the Pluto discussion...
How is an additional 2 hours going to make any difference specifically?
I was talking about a delay of up to 6 hours, but any delay can make a difference.
All other (non-Pluto) stations have guide data for many days and reliable series/episode information. Recordings can be setup well in advance or automated as I have done. With the current available Pluto information, the normal systems are not practical to use. The only reliable way to set recordings is for a human to look at the guide data. In that I am not willing to constantly monitor the Pluto guide, the more data available at the times when I do look at the guide, the better off I am.
But it isn't a 6 hour difference. It's 2.
I tried correcting you and your first sentence incorrectly says 6 hours. Glad you were able to get Docker working anyhow.
Yea, I'm still confused about the math here so I gave up trying to figure it out. I also saved a ton of CPU cycles on my aging server by ditching Docker and using the php method by HankLloydRight.
Anyone can feel free to correct me but the docker method has the ability to update every hour.
Hanks method has the ability to update every 3 hours, even if you select 1 hour in the settings.
So the difference is 2 hours.
I also dumped docker. However, if I find another use for docker, which is a good possibility, I will go back to using it because it will already be running.
I just made a big post in the "Non-Docker" thread that will hopefully address the EPG timing issues.
Sorry your math was wrong, but it is a moot point since @HankLloydRight has changed his system from updating every 3 hours to updating every 30 minutes, and allowing his users to poll him once per hour. This brings the maximum delay down from 6 hours to 90 minutes, compared to 60 minutes with Docker. The 30 minute difference is small enough to be ignored, especially since the average delay is down to 45 minutes.
Looks like the m3u currently is missing channel-number= tags, so there is no difference. I may add these for people who want to use pluto numbering.
I am working on improving the guide data, so specifics about which channels and programs are not acting well would be appreciated.
I am getting some Pluto schedule data through Schedules Direct, But they only have about 1/3 of the channels. The people at Schedules Direct say that they contacted Pluto about this and Pluto told them that this is all they are willing to release.
The SD data comes out many days in advance. I checked for 5 days out and the data was there, but only for a select set of channels.
What I would really like to be getting are season and episode numbers, and for Channels to know which episodes I have already seen.
I fixed this in v1.2.7 of the docker so it should be much better now.
