I like old game shows and Pluto has Buzzr TV. The only problem is that gameshows on Pluto always say the same thing. Such as Password Plus always says 9-24-84 as the airdate so once I record one Channels thinks that show has been recorded and won't record future showings. I have to go in and manually unqueue each show tell it to record it. Any thoughts on how to fix this?
Not sure why that's happening.
I see the date-time of the airing used in the Program ID, so it should record them all.
ProgramID "pluto/62704d73725d090014956e22/20220927220000--0700",OriginalDate "2022092722"
ProgramID "pluto/62704d73725d090014956e22/20220927223000--0700",OriginalDate "2022092722"
What are you using for your Pluto source?
Mine is Pluto for Channels
Ditto
My version says 1.18.0
I am unsure how to update it, I will look into that
You must be running the ancient (2020-12-28) v 1.0.18
Yes, I believe I am. I take it there is a newer version I need to get!
Yah, pull and run the latest v1.2.13
https://hub.docker.com/r/jonmaddox/pluto-for-channels/tags
Cool, thanks for your help. I get this working tomorrow!
