For the life of me, i cant get this to work. Not an expert in docker but I have used and currently use a few docker containers.
no matter what port i try, i cant connect to it. it refuses the connection. ive used to default ports, ive changed ports and still nothing.
i use synology's docker implementation (in their app store) with other containers and they connect and work fine but this container wont connect.
ive tried it on a windows 10 machine with the Docker gui, same thing. it installs, downloads, and logs show that the playlist and xml are being served, but i cant connect to it whether it be by the local machines ip address or loopback address.
the container logs do not show any errors and it always shows success after the playlist and xml.
there are no firewalls or anything.
any tips, ideas?
thanks.
I'll manually refresh for now and will keep an eye out for your continued development of this great feature. Thank you.
