Would it be possible that one could set an “Auto tune “feature such that, like setting a recording in advance the channel auto jumps to that station?
Thanks for reading!
Thanks for reading!
The DVR already puts a tuner to the correct station before recording. DVR would record the wrong shows otherwise.
Hi Sparky, I think I requested what your after a while back and received little feedback. I know I would use this feature daily, below is a link to my request.
You might be able to automate something of this sort using Channels' HTTP API, querying the server for the channel/program. The problem with this though, is that the client must be on and active for it to receive the HTTP request to tune. If you have to manually turn on the client, it's just as simple to tune your program.
