Project One-Click: All-in-One Installations of Docker Extensions and CDVR Custom Channels
Sorry about that. While the zip_code variable didn't do anything anymore, the startup code still required it. But the latest mlbserver update removed the variable entirely, so you could once again remove it from your Docker config if you like. :slight_smile:
I am trying to do the one-click Frndly TV install, but I am getting this error:
JSON response from http://192.168.29.131:9000/api/stacks/create/standalone/string?endpointId=2:
{"message":"Unable to find an environment with the specified identifier inside the database","details":"Object not found inside the database (bucket=endpoints, key=2)"}
false
I am not sure what steps I should take to troubleshoot?
Does ChannelsDVR have to be running in Docker for this to work? Can it be running in Windows (11).
Try using the Docker Compose a couple of posts up, with the new PORTAINER_ENV value set to 3. This might be a new wrinkle with the latest version of Portainer, that you could help prove/disprove.
Thanks, I will.
edit...
I used the script from post 340. OliveTin started right up. I get the same error, however.
Could this be my issue, I see it in the Post-install Health Check?
If the listed folders are NOT visible, AND you have your Channels DVR and Docker on the same system:
Channels reports this path as...
C:\ProgramData2\DVR
When using a Windows path in Portainer, change the backslashes to slashes like this...
C:/ProgramData2/DVR
When using WSL with a Linux distro and Docker Desktop, it's also possible to use...
/mnt/c/ProgramData2/DVR
I updated Portainer and still only have one environment 'local' which is '2'
:roll_eyes:
I got it now
Change these environment variables
CHANNELS_DVR2_HOST=another-server	# change it to CHANNELS_DVR2_HOST=
CHANNELS_DVR2_PORT=8089	# change it to CHANNELS_DVR2_HOST=
CHANNELS_DVR_HOST=local-server	# change it to CHANNELS_DVR_HOST=IP ADDRESS OF YOUR CHANNELS DVR SERVER HERE
DOMAIN=192.168.7.109:8089	# change it to DOMAIN=local
Add this line
PORTAINER_HOST=IP ADDRESS OF YOUR CHANNELS DVR SERVER HERE
Anything else I am missing before I deploy the stack, this time I am saving these docker compose on a notepad.
version: '3.9'
services:
  olivetin: # This docker-compose typically requires no editing. Use the Environment variables section of Portainer to set your values.
    # 2025.02.21
    # GitHub home for this project: https://github.com/bnhf/OliveTin.
    # Docker container home for this project with setup instructions: https://hub.docker.com/repository/docker/bnhf/olivetin.
    image: bnhf/olivetin:${TAG} # Add the tag like latest or test to the environment variables below.
    container_name: olivetin
    hostname: olivetin
    dns_search: ${DOMAIN} # For Tailscale users using Magic DNS, add your Tailnet (tailxxxxx.ts.net) to use hostnames for remote nodes, otherwise use your local domain name.
    ports:
      - ${HOST_PORT}:1337
    environment:
      - CHANNELS_DVR=${CHANNELS_DVR_HOST}:${CHANNELS_DVR_PORT} # Add your Channels DVR server in the form CHANNELS_DVR_HOST=<hostname or ip> and CHANNELS_DVR_PORT=<port>.
      #- CHANNELS_DVR_ALTERNATES=${CHANNELS_DVR2_HOST}:${CHANNELS_DVR2_PORT} # Space separated list of alternate Channels DVR servers to choose from in the form hostname:port or ip:port.
      - CHANNELS_CLIENTS=${CHANNELS_CLIENTS} # Space separated list of Channels DVR clients you'd like notifications sent to in the form hostname or IP.
      - ALERT_SMTP_SERVER=${ALERT_SMTP_SERVER} # SMTP server to use for sending alert e-mails. smtp.gmail.com:587 for example.
      - ALERT_EMAIL_FROM=${ALERT_EMAIL_FROM} # Sender address for alert e-mails.
      - ALERT_EMAIL_PASS=${ALERT_EMAIL_PASS} # SMTP "app" password established through GMail or Yahoo Mail. Do not use your everyday e-mail address.
      - ALERT_EMAIL_TO=${ALERT_EMAIL_TO} # Recipient address for alert e-mails.
      - UPDATE_YAMLS=${UPDATE_YAMLS} # Set this to true to update config.yaml.
      - UPDATE_SCRIPTS=${UPDATE_SCRIPTS} # Set this to true to update all included scripts.
      - TZ=${TZ} # Add your local timezone in standard linux format. E.G. US/Eastern, US/Central, US/Mountain, US/Pacific, etc.
      - PORTAINER_TOKEN=${PORTAINER_TOKEN} # Generate via <username> dropdown (upper right of WebUI), "My account", API tokens.
      - PORTAINER_HOST=${PORTAINER_HOST} # Hostname or IP of the Docker host you're running Portainer on.
      - PORTAINER_PORT=${PORTAINER_PORT} # https port you're running Portainer on. 9443 is the default.
      - PORTAINER_ENV=3 # Set this is if you're using an alternate Portainer Environment for some reason. 2 is the default.
    volumes:
      - ${HOST_DIR}/olivetin:/config # Add the parent directory on your Docker you'd like to use.
      - ${DVR_SHARE}:/mnt/${CHANNELS_DVR_HOST}-${CHANNELS_DVR_PORT} # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your Channels DVR network share.
      - ${LOGS_SHARE}:/mnt/${CHANNELS_DVR_HOST}-${CHANNELS_DVR_PORT}_logs # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your Channels DVR logs network share.
      - ${TUBEARCHIVIST_SHARE}:/mnt/${CHANNELS_DVR_HOST}-${CHANNELS_DVR_PORT}_ta # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your TubeArchivist videos network share.
      #- ${DVR2_SHARE}:/mnt/${CHANNELS_DVR2_HOST}-${CHANNELS_DVR2_PORT} # Note that these volume mounts should always be to /mnt/hostname-port or /mnt/ip-port (dash rather than a colon between).
      #- ${LOGS2_SHARE}:/mnt/${CHANNELS_DVR2_HOST}-${CHANNELS_DVR2_PORT}_logs # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your Channels DVR logs network share.
      #- ${TUBEARCHIVIST2_SHARE}:/mnt/${CHANNELS_DVR2_HOST}-${CHANNELS_DVR2_PORT}_ta # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your TubeArchivist videos network share.
      - /var/run/docker.sock:/var/run/docker.sock
    restart: unless-stopped
  static-file-server:
    image: halverneus/static-file-server:latest
    container_name: static-file-server
    ports:
      - ${HOST_SFS_PORT}:8080
    environment:
      - FOLDER=${FOLDER}
    volumes:
      - ${HOST_DIR}/olivetin/data:${FOLDER}
#volumes: # use this section if you've setup a docker volume named channels-dvr, with CIFS or NFS, to bind to /mnt/dvr inside the container. Set ${HOST_DIR} to channels-dvr (HOST_DIR=channels_dvr) in that example.
  #channels-dvr:
    #external: true
  #channels-dvr-logs:
    #external: true
  #tubearchivist:
    #external: true
TAG=latest
DOMAIN=local
HOST_PORT=1337
CHANNELS_DVR_HOST=192.168.7.109:8089
CHANNELS_DVR_PORT=8089
CHANNELS_DVR2_HOST=
CHANNELS_CLIENTS=appletv4k-livingroom 192.168.7.187
[email protected]
ALERT_EMAIL_PASS=XXXXXXXXXX
[email protected]
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
TZ=US/Arizona
HOST_DIR=/volume1/docker
DVR_SHARE=/volume1/chDVRtve
LOGS_SHARE=/volume1/docker/channelsdvr
TUBEARCHIVIST_SHARE=/volume1/docker/channelsdvr
HOST_SFS_PORT=8080
FOLDER=/web
PORTAINER_HOST=192.168.7.109:8089
PORTAINER_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
PORTAINER_PORT=9443
Good idea :smile:
Update these
CHANNELS_DVR2_PORT=8089              # change it to CHANNELS_DVR2_PORT=
CHANNELS_DVR_HOST=192.168.7.109:8089 # change it to CHANNELS_DVR_HOST=192.168.7.109
PORTAINER_HOST=192.168.7.109:8089    # change it to PORTAINER_HOST=192.168.7.109
Remove the port numbers and keep the DVR2 PORT empty?
CHANNELS_DVR2_PORT=8089 change to CHANNELS_DVR2_PORT=
CHANNELS_DVR_HOST=192.168.7.109:8089 change to CHANNELS_DVR_HOST=192.168.7.109
PORTAINER_HOST=192.168.7.109:8089 change to PORTAINER_HOST=192.168.7.109
Anything critical missing here?
TAG=latest
DOMAIN=local
HOST_PORT=1337
CHANNELS_DVR_HOST=192.168.29.131
CHANNELS_DVR2_HOST=
CHANNELS_DVR2_PORT=
CHANNELS_CLIENTS=Living Room
[email protected]
ALERT_EMAIL_PASS=xxxxxxxxxxxxxxxx
[email protected]
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
TZ=US/Eastern
HOST_DIR=/data
DVR_SHARE=/mnt/dvr
LOGS_SHARE=/mnt/channelsdvr
TUBEARCHIVIST_SHARE=/mnt/dvr
HOST_SFS_PORT=8080
FOLDER=/web
PORTAINER_TOKEN=ptr_RoCJi+tUL6FZFHvZysHNd849xqbcREDDuQlKbqg8sl4=
PORTAINER_HOST=192.168.29.131
This should be the actual LAN hostname (hostnames never have spaces), or IP address of any Channels client you'd like to be able to send onscreen messages to.
Also, if you could update OliveTin to the :latest (:2025.02.22), pushed a few minutes ago, and then re-run a Post-Install Healthcheck. Please post the results shown in Standard Output (no Standard Error) here, as there are a couple of things I'd like to verify.
Under Clients in the CDVR web settings, it says my ATV 4K is named "Living Room"?
That's CDVR's informal name for the device not the actual LAN hostname. Using the LAN IP for this value is probably the easiest, and it's shown on that same page in the CDVR webUI under that informal name.
Great! I will. I will look for how to update OT.
You can either use Watchtower, or if you don't have that installed, stop the OliveTin stack. Then, go into the Stack Editor, and click Update the stack followed by selecting the Re-pull and redeploy slider.
Is that option available on the free version of Docker? I don't see it.
