Project One-Click: All-in-One Installations of Docker Extensions and CDVR Custom Channels
You probably need to correct these directories
Do I need to copy the new stack info before updating the stack?
edit...
I copy/pasted the info from post #1, and OliveTin says version 2025.02.22.
Thanks.
ChannelsDVR location is on same Windows 11 PC as Docker. The location is C:\ProgramData2\DVR
What should the values be?
You should be able use C:/ProgramData2/DVR for your LOGS_SHARE value.
That's what you want to see! Looks good.
I edited my post for an error message when I run the Pluto one click command.
Your most recent post is for SamsungTVPlus, and indicates success.
Ahh I see, I had to give it a bit of time. Thank you for your help and dedication in creating this project!!
Checking your OliveTin-for-Channels installation...
(extended_check=false)
Version 2025.02.22
Checking that your selected Channels DVR server (192.168.29.131:8089) is reachable by URL:
HTTP Status: 200 indicates success...
100  1276  100  1276    0     0   207k      0 --:--:-- --:--:-- --:--:--  249k
HTTP Status: 200
Effective URL: http://192.168.29.131:8089/
Checking that your selected Channels DVR server's data files (/mnt/192.168.29.131-8089) are accessible:
Folders with the names Database, Images, Imports, Logs, Movies, Streaming and TV should be visible...
total 4
drwxr-xr-x 2 root root   40 Feb 22 17:35 .
drwxr-xr-x 1 root root 4096 Feb 22 19:44 ..
If the listed folders are NOT visible, AND you have your Channels DVR and Docker on the same system:
Channels reports this path as...
C:\ProgramData2\DVR
When using a Windows path in Portainer, change the backslashes to slashes like this...
C:/ProgramData2/DVR
When using WSL with a Linux distro and Docker Desktop, it's also possible to use...
/mnt/c/ProgramData2/DVR
Checking that your selected Channels DVR server's log files (/mnt/192.168.29.131-8089_logs) are accessible:
Folders with the names data and latest should be visible...
total 4
drwxrwxrwx 1 root root  512 Feb 22 19:43 .
drwxrwxrwx 1 root root  512 Feb 22 18:59 Database
drwxrwxrwx 1 root root  512 Feb 21 16:49 Images
drwxrwxrwx 1 root root  512 Feb 21 16:49 Imports
drwxrwxrwx 1 root root  512 Feb 21 17:46 Streaming
drwxrwxrwx 1 root root  512 Feb 22 19:44 olivetin
C:\ProgramData\ChannelsDVR
C:/ProgramData/ChannelsDVR
/mnt/c/ProgramData/ChannelsDVR
Checking if your Portainer token is working on ports 9000 and/or 9443:
Portainer http response on port 9000 reports version 2.27.0
Portainer https response on port 9443 reports version
Portainer Environment ID for local is
Here's a list of your current OliveTin-related settings:
HOSTNAME=olivetin
CHANNELS_DVR=192.168.29.131:8089
CHANNELS_DVR_ALTERNATES=
CHANNELS_CLIENTS=192.168.29.245
ALERT_EMAIL_FROM=[Redacted]@gmail.com
ALERT_EMAIL_PASS=[Redacted]
ALERT_EMAIL_TO=[Redacted]@gmail.com
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
PORTAINER_TOKEN=[Redacted]
PORTAINER_HOST=192.168.29.131
PORTAINER_PORT=
PORTAINER_ENV=
Here's the contents of /etc/resolv.conf from inside the container:
# Generated by Docker Engine.
# This file can be edited; Docker Engine will not make further changes once it
# has been modified.
nameserver 127.0.0.11
search local
options ndots:0
# Based on host file: '/etc/resolv.conf' (internal resolver)
# ExtServers: [192.168.65.7]
# Overrides: [search]
# Option ndots from: internal
Here's the contents of /etc/hosts from inside the container:
127.0.0.1	localhost
::1	localhost ip6-localhost ip6-loopback
fe00::0	ip6-localnet
ff00::0	ip6-mcastprefix
ff02::1	ip6-allnodes
ff02::2	ip6-allrouters
172.19.0.2	olivetin
As for organizr,
this is my docker compose,
version: '3.9'
services:
  organizr:
    image: organizr/organizr:latest
    container_name: organizr
    hostname: organizr
    ports:
      - 81:80
    environment:
      - PUID=nobody
      - PGID=nobody
      - TZ=US/Arizona
    volumes:
      - /volume1/docker/organizr/data/organizr:/config
    restart: unless-stopped
But when I go to http://htpc6/, I get nothing.
That's the hostname for my Docker/Portainer host.
You should try:
http://192.168.29.131:81
Looks like these two should be:
DVR_SHARE=C:/ProgramData2/DVR
LOGS_SHARE=C:/ProgramData/ChannelsDVR
Looks like you have Portainer installed only for http on port 9000, so I'll need to make a modification to my Healthcheck script to account for that -- as I'm trying to confirm your Portainer Environment ID.
@Channels2021 That's done, so Re-pull and redeploy again, after making the other changes above -- and then re-post the healthcheck.
He should also add this env var
PORTAINER_PORT=9443
Version 2025.02.22
100  1276  100  1276    0     0   249k      0 --:--:-- --:--:-- --:--:--  249k
HTTP Status: 200
total 4
drwxr-xr-x 1 root root 4096 Feb 22 20:45 ..
C:\ProgramData2\DVR
C:/ProgramData2/DVR
total 8
drwxrwxrwx 1 root root  512 Feb 21 16:54 .
-rwxrwxrwx 1 root root  838 Feb 21 16:54 Channels DVR Server.lnk
drwxrwxrwx 1 root root  512 Feb 21 17:29 data
drwxrwxrwx 1 root root  512 Feb 21 16:54 latest
HOSTNAME=olivetin
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
PORTAINER_PORT=
PORTAINER_ENV=
search local
options ndots:0
127.0.0.1	localhost
172.19.0.2	olivetin
TAG=latest
DOMAIN=local
HOST_PORT=1337
CHANNELS_DVR_HOST=192.168.29.131
CHANNELS_DVR_PORT=8089
CHANNELS_DVR2_HOST=
CHANNELS_DVR2_PORT=
[email protected]
ALERT_EMAIL_PASS=xxxxxxxxxxxxxxxx
[email protected]
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
TZ=US/Eastern
HOST_DIR=/data
TUBEARCHIVIST_SHARE=/mnt/dvr
HOST_SFS_PORT=8080
FOLDER=/web
PORTAINER_TOKEN=ptr_RoCJi+tUL6FZFHvZysHNd849xqbcREDDuQlKbqg8sl4=
PORTAINER_PORT=9443
I would change to this
HOST_DIR=C:/ProgramData
And unless you use TUBEARCHIVIST and know where you want those videos
Failed to deploy a stack: failed to load the compose file: invalid spec: :/mnt/192.168.29.131-8089_ta: empty section between colons
