Project One-Click: All-in-One Installations of Docker Extensions and CDVR Custom Channels
Failed to deploy a stack: failed to load the compose file: invalid spec: :/mnt/192.168.29.131-8089_ta: empty section between colons
@bnhf
Here's my healthcheck from OT4C 2025-02-22
Checking your OliveTin-for-Channels installation...
(extended_check=false)
Version 2025.02.23
Checking that your selected Channels DVR server (192.168.1.4:8089) is reachable by URL:
HTTP Status: 200 indicates success...
100  1276  100  1276    0     0  16571      0 --:--:-- --:--:-- --:--:-- 16571
HTTP Status: 200
Effective URL: http://192.168.1.4:8089/
Checking that your selected Channels DVR server's data files (/mnt/192.168.1.4-8089) are accessible:
Folders with the names Database, Images, Imports, Logs, Movies, Streaming and TV should be visible...
total 72
drwxrwxrwx  2 1027 root    4096 Feb 10 15:22 #recycle
d--------- 11 1027 root    4096 Feb  9 12:52 .
drwxr-xr-x  4 root root    4096 Feb 22 18:39 ..
drwxrwxrwx  4 1027 root    4096 Feb  9 12:52 @eaDir
d--------- 32 1027 242120  4096 Feb 22 09:47 Database
d---------  3 1027 242120 20480 Feb 12 19:51 Images
d---------  5 1027 242120  4096 Mar 18  2022 Imports
d---------  4 1027 242120  4096 Feb 10  2022 Logs
d---------  2 1027 242120 12288 Jan  9 15:49 Movies
d---------  6 1027 242120  4096 Feb  9 20:27 Streaming
d--------- 55 1027 242120  4096 Feb 12 19:51 TV
If the listed folders are NOT visible, AND you have your Channels DVR and Docker on the same system:
Channels reports this path as...
/shares/dvr
Checking that your selected Channels DVR server's log files (/mnt/192.168.1.4-8089_logs) are accessible:
Folders with the names data and latest should be visible...
total 36
drwxr-xr-x  9 1027 users 4096 Feb 22 09:47 .
drwxr-xr-x  2 root root  4096 Feb 16 20:08 2025.02.15.0247
drwxr-xr-x  2 root root  4096 Feb 17 18:00 2025.02.18.0129
drwxr-xr-x  2 root root  4096 Feb 18 14:51 2025.02.18.2211
drwxr-xr-x  2 root root  4096 Feb 19 10:22 2025.02.19.0538
drwxr-xr-x  2 root root  4096 Feb 19 12:23 2025.02.19.1823
drwxr-xr-x  2 root root  4096 Feb 22 09:47 2025.02.22.0936
drwxr-xr-x 13 root root  4096 Feb 22 18:15 data
lrwxrwxrwx  1 root root    15 Feb 22 09:47 latest -> 2025.02.22.0936
/channels-dvr
Checking if your Portainer token is working on ports 9000 and/or 9443:
Portainer http response on port 9000 reports version 2.27.0
Portainer Environment ID for local is 2
Portainer https response on port 9443 reports version 2.27.0
Here's a list of your current OliveTin-related settings:
HOSTNAME=olivetin
CHANNELS_DVR=192.168.1.4:8089
CHANNELS_DVR_ALTERNATES=192.168.1.4:8189 192.168.1.4:8190 192.168.1.4:8289 192.168.1.4:8389 192.168.1.4:8489
CHANNELS_CLIENTS=
ALERT_SMTP_SERVER=
ALERT_EMAIL_FROM=[Redacted]@
ALERT_EMAIL_PASS=[Redacted]
ALERT_EMAIL_TO=[Redacted]@
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
PORTAINER_TOKEN=[Redacted]
PORTAINER_HOST=192.168.1.4
PORTAINER_PORT=9443
PORTAINER_ENV=
Here's the contents of /etc/resolv.conf from inside the container:
search local
nameserver 127.0.0.11
options ndots:0
Here's the contents of /etc/hosts from inside the container:
127.0.0.1	localhost
::1	localhost ip6-localhost ip6-loopback
fe00::0	ip6-localnet
ff00::0	ip6-mcastprefix
ff02::1	ip6-allnodes
ff02::2	ip6-allrouters
172.19.0.2	olivetin
Not sure why it reports Version 2025.02.23
My script that updates the date at build time must be using UTC. I'll see what I can do about it. Thanks for letting me know.
To allow for leaving the TUBEARCHIVIST_SHARE value blank, go ahead and comment out this line in your Docker Compose. I'll make this the default as I update the OliveTin Compose on the forum tomorrow.
It'll look like this in the volumes: section from here forward:
      #- ${TUBEARCHIVIST_SHARE}:/mnt/${CHANNELS_DVR_HOST}-${CHANNELS_DVR_PORT}_ta # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your TubeArchivist videos network share.
There's not a huge group of people using this Action, so it makes sense.
Version 2025.02.22
Checking that your selected Channels DVR server (192.168.29.131:8089) is reachable by URL:
100  1276  100  1276    0     0   155k      0 --:--:-- --:--:-- --:--:--  178k
HTTP Status: 200
Effective URL: http://192.168.29.131:8089/
Checking that your selected Channels DVR server's data files (/mnt/192.168.29.131-8089) are accessible:
total 4
drwxrwxrwx 1 root root  512 Feb 22 19:43 .
drwxr-xr-x 1 root root 4096 Feb 23 01:57 ..
drwxrwxrwx 1 root root  512 Feb 22 18:59 Database
drwxrwxrwx 1 root root  512 Feb 21 16:49 Images
drwxrwxrwx 1 root root  512 Feb 21 16:49 Imports
drwxrwxrwx 1 root root  512 Feb 21 17:46 Streaming
drwxrwxrwx 1 root root  512 Feb 22 19:44 olivetin
C:\ProgramData2\DVR
When using a Windows path in Portainer, change the backslashes to slashes like this...
C:/ProgramData2/DVR
When using WSL with a Linux distro and Docker Desktop, it's also possible to use...
/mnt/c/ProgramData2/DVR
Checking that your selected Channels DVR server's log files (/mnt/192.168.29.131-8089_logs) are accessible:
total 8
drwxrwxrwx 1 root root  512 Feb 21 16:54 .
-rwxrwxrwx 1 root root  838 Feb 21 16:54 Channels DVR Server.lnk
drwxrwxrwx 1 root root  512 Feb 21 17:29 data
drwxrwxrwx 1 root root  512 Feb 21 16:54 latest
C:\ProgramData\ChannelsDVR
C:/ProgramData/ChannelsDVR
/mnt/c/ProgramData/ChannelsDVR
HOSTNAME=olivetin
CHANNELS_DVR=192.168.29.131:8089
CHANNELS_CLIENTS=192.168.29.245
ALERT_EMAIL_FROM=[Redacted]@gmail.com
ALERT_EMAIL_TO=[Redacted]@gmail.com
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
PORTAINER_HOST=192.168.29.131
PORTAINER_PORT=
PORTAINER_ENV=
# Generated by Docker Engine.
# This file can be edited; Docker Engine will not make further changes once it
# has been modified.
search local
options ndots:0
# Based on host file: '/etc/resolv.conf' (internal resolver)
# ExtServers: [192.168.65.7]
# Overrides: [search]
# Option ndots from: internal
127.0.0.1	localhost
172.19.0.2	olivetin
TAG=latest
DOMAIN=local
HOST_PORT=1337
CHANNELS_DVR_HOST=192.168.29.131
CHANNELS_DVR_PORT=8089
CHANNELS_DVR2_HOST=
CHANNELS_DVR2_PORT=
[email protected]
ALERT_EMAIL_PASS=xxxxxxxxxxxxxxxx
[email protected]
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
TZ=US/Eastern
HOST_DIR=C:/ProgramData
DVR_SHARE=C:/ProgramData2/DVR
LOGS_SHARE=C:/ProgramData/ChannelsDVR
TUBEARCHIVIST_SHARE=
HOST_SFS_PORT=8080
FOLDER=/web
PORTAINER_TOKEN=ptr_RoCJi+tUL6FZFHvZysHNd849xqbcREDDuQlKbqg8sl4=
PORTAINER_PORT=9443
You didn't get most recent version of OliveTin before running this Action. It should have been 2025.02.23 (UTC time). Could you use the Re-pull and redeploy option, and run it again please?
Also, when you post logs, code snippets, yaml, env var lists and such on this forum -- be sure to use 3 backticks before and after the text, so that it ends up in an easier to read code block.
New bnhf/olivetin:latest (aka bnhf/olivetin:2025.02.23) pushed late yesterday with support for DELETING Channels DVR Custom Channels sources, and associated Portainer stacks, created by Project One-Click. This makes it very easy to add an extension to check it out, and then remove it just as quickly and easily:
Screenshot 2025-02-23 140158
THANK YOU FOR YOUR HELP!!! You and @chDVRuser ROCK!!!
Confused :confused:
Looks like it was just pushed a couple hours ago https://hub.docker.com/r/bnhf/olivetin/tags.
You miss little. :slight_smile: I pushed an update shortly after the post as I realized it needed a tweak.
Actually it's my DIUN that notified me.
I have it set to check all my images and also added some I'm not running to check on.
New bnhf/olivetin:latest (aka bnhf/olivetin:2025.02.24) pushed today, with an improvement to the new Delete a Project One-Click Channels DVR Extension Action.
For supported projects, this Action now:
  • Deletes any CDVR Custom Channels sources created for a given extension
  • Stops any running stacks created for a given extension
  • Deletes the stopped stack for a given extension
  • Deletes the container image pulled for a given extension (New!)
The last item, concerning deleting the image, is today's improvement. By deleting the image, this ensures that if a given extension is spun-up a later time, it will pull the latest as opposed to using the image present locally -- which could be out-of-date.
@Channels2021 Have you had a chance to pull the :latest (now :2025.02.24) and re-run the healthcheck? If so, could you post it please?
I removed that line and it loaded the stack before. The newest changes give me this error and the stack no longer loads. I am using the one from post #1 in this thread.
That error can only be from that line I wanted you to comment out -- so something wasn't right the second time you did it. I've updated the compose in Post #1 now, so you can copy and paste it as is. Be sure to use the Re-pull and redeploy slider when you update the stack.
I haven't been able to retest this but I will soon. Thanks a lot!
Hoping for some guidance. I've been using CDVR for a number of years, works well & have setup some docker containers for Frndly, Tubi & Tubo in addition to Xfinity TVE & HDHR antenna. I am running on an older Intel Mac mini that I would like to retire. I have recently installed OliveTin and moving the add-ins there. I wanted to move CDVR to my wife's very lightly used M4 Mac mini as she only does light web/email sporadically. Is there a recommended, secure way to setup on her Mac? I am currently the named Apple user on the Intel & I was planning on setting up myself as a named user on her Mini to migrate that over. However as I think of a fresh setup should I setup a more generic OS user on this Mac and only use for CDVR? I am Apple using screen sharing very successfully in the house (and Tailscale remotely). Appreciate any input, thanks in advance.
Makes sense to me to setup a separate user for CDVR and Docker/Portainer, but I'm not an everyday Mac user. Maybe @Fofer has some thoughts on this?
I have Channels DVR installed and running on my primary macOS user account. AFAIK this is the wisest path because otherwise it wouldn’t launch on its own after a reboot? As it stands now, as I understand it, I have to log in to the primary account first for CDVR hardware transcoding to work too. Maybe that’s outdated information now? I’m not really sure. Here's information I previously read that led me to those conclusions though:
