Provider - DirecTV Stream
Now I've got the source reloaded but nothing plays. DirecTV Stream has been a cluster for me since signing up this morning.
Try selecting DirecTv instead of Directv Stream. Use the same login credentials. I had to do that to get ABC back a few weeks ago. Might work for your missing channels.
Thank you. I tried that and got even fewer channels. I can now get everything through the Stream login, except Fox local and FS2. What's weird is now I can watch DTV everywhere except on a PC or MAC. I get a locked out for 24 hours notice but everything works fine now through Channels on the the DTV apps for ios and AppleTV. I called DTV and they cannot figure out the problem. A password reset did not work. They are escalating the issue.
I had a problem with my local Fox as well. That is now working with the Direct TV source instead of the DTV stream source. It did take a couple of days to show up, probably because the TVE is only during prime time.
Thanks. I'll keep rescanning the missing individual channels in the DTV and DTV Stream sources.
For your Fox channel, it will only authenticate during Prime Time Hours.
Thanks for the advice, everyone. I rescanned on Stream and got everything except Fox. As a bonus, I also added through the DirecTV source and got CBS, even though the MySports package doesn't come with it.
Update: and now Fox works as well! The only network I cannot get with DirecTV stream is NBC. It doesn’t even show up as an option to add.
I got it to authenticate, but I wasn't able to watch it. I got the 503 service unavailable error; streaming to the tuner failed. It never loaded the guide either.
NBC and it’s affiliates are DRM so not available.
On DirecTV Stream and lost all Discovery channels around the middle of the day on 7/17. I was watching and it behaved like my internet had gone out. When I would try to tune a channel I would get the form not available error. I've since updated to the latest beta, deleted the tuner and recreated it and now the channels don't even appear in my channel list, so I can even try to get the exact error.
Edit to update, the problem I was seeing before updating and deleting and recreating my tuner was the same as they are experiencing on the Philo thread. So, it's not specific to Philo or DTV Stream, but a change on the TVE side.
Directv Stream
Synology NAS
Discovery channels working here.
Running on Windows 11 Pro server.
Here is what I get when I go to the rescan channels UI:
So, no login form.
Did you run the troubleshooting from the support tab on the web ui?
Same here, Win 11 laptop.
Troubleshooting shows all good.
I am on the current Stable release, Version: 2025.06.01.2212
Update:
Tried going to Science channel on Discovery Go on the laptop, Chrome browser, Science Ch started,
While it was still up went back to Onn box, still fails.
Stopped and restarted CDVR, still fails to authorize,
the Manage Lineup does NOT show any problems with any channel. Did not do a rescan.
I tried Discovery Go, Science Ch using DirectvStream and DirecTV, Chrome browser
Still fails both ways on Onn, Firestick.
Failed to start stream for ch6110: TVE: adobe auth reg code: no login form found
Link your provider at go.discovery.com
Does it show all of the Discovery Networks available to you?
Capture
I log in on that page and all the channels are available in that browser, and I am able to watch them live without issue. After I did that, I went back to channels and tried to scan the channels again, and still no discovery channels, unfortunately.
Same issue as others. Can login to website with no problems. Updated source password - did not make a difference. Reminds me of same adobe issue in the past for other stations.
Well TVE side on CDVR.
TVE works fine using Discovery Go on browser.
Maybe the devs can fix this within CDVR.
I had Cox source disabled but just enabled it.
Tried with Cox source
and all Discovery Ch auth and play.
Tried again on admin page using DirectvStream and they play
BUT using cox source per the logs.
So it’s not ALL sources failing, Cox works.
It appears it is only affecting Win 11 servers. Working fine on Synology NAS.
