I have a Windows 11 server and Spectrum is my TVE source. As of now, my Discovery channels are streaming without issue.
When using CDVR TVE, you should always update pre-release when you encounter TVE issues.
See TVE Troubleshooting tips
Yes, I always try the Pre-Release whenever I have issues, It didn't fix the problem this time, which is why I posted. I updated to the new one in your message and tried again, still no good.
So, I decided to try a reinstall. Uninstalled what I had, rebooted, reinstalled, rebooted and tried to set up the tuner again using the stable version. Still no good. Updated to the Pre-Release again and tried again, still not getting any discovery channels.
Edited to add that the new Pre-Release changed the error message to - adobe auth reg code: Cable provider authentication failed
Wouldn't hurt to submit diagnostic logs again if the latest release didn't fix it.
True, try the latest release β¦.. maybe.
I always read the update notes, i have not seen any regarding Discovery channels TVE which the devs usually explicitly mention, so I stick with the Stable.
BOOM
I just saw an update mentioning this issue.
Will try now
v2025.07.19.2021
β’ Try to fix DIRECTV authentication
I installed the latest pre-release, stopped and restarted CDVR, Disabled Cox so it wouldn't try that Source.
Still failed from Admin page and Onn. Onn failure says
Connection Lost, Streamiing to tuner failed. Press play to try again.(Tuner unreachable)
Lots of stuff in the logs, here's a short snippet from the very end and a longer snippet from the logs:
. From the very end Note: I was starting FoodNetwork but it mentions science_stream error ALSO
2025/07/19 19:01:09.122251 [TVE] action=science_stream error={[{access.denied.missingpackage 403 {[FoodNetwork] }}] {{[]}}}
2025/07/19 19:01:09.128401 [ERR] Failed to start stream for ch6102: TVE: playback info: access.denied.missingpackage: FoodNetwork
. Longer
action=fill_form u= [my user id here]
2025/07/19 19:00:54.685257 [HLS] Couldn't generate stream playlist for ch6102-dANY-ip127.0.0.1: HLS: 901 Tuner Unreachable: Could not tune to ch6102 after 12s
2025/07/19 19:00:54.685833 [HLS] Stopping transcoder session ch6102-dANY-ip127.0.0.1 (out=0s finished=false first_seq=0 last_seq=-1)
2025/07/19 19:00:54.685833 [ERR] Failed to start stream for ch6102: context canceled
2025/07/19 19:00:58.378970 [TVE] action=check_result
2025/07/19 19:00:58.383322 [TVE] action=auth_timed_out
2025/07/19 19:00:58.383322 [TVE] action=screenshot
2025/07/19 19:00:58.432675 [TVE] action=screenshot file=tve_error_screenshot.png size=36301
2025/07/19 19:00:58.433178 [TVE] action=capture_html
2025/07/19 19:00:58.437249 [TVE] action=capture_html file=tve_error_screenshot.html size=61278
2025/07/19 19:00:58.437757 [TVE] action=capture_html
2025/07/19 19:00:58.439770 [TVE] action=capture_html file=tve_error_screenshot.html size=61278
2025/07/19 19:00:59.748863 [TVE] action=version product=Chrome/138.0.7204.158 jsVersion=13.8.258.26 protocol=1.3 revision=@903c1a4e1274a274ac03d20a24ab16634d064418
2025/07/19 19:00:59.751017 [TVE] action=page_ready chromeVersion=138
2025/07/19 19:00:59.752253 [TVE] action=navigate url=https://sp.auth.adobe.com/api/v1/authenticate?reg_code=EFTZ4MM&mso_id=YouTubeTV&domain_name=adobe.com&requestor_id=discovery&noflash=true&deviceType=html5&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2025/07/19 19:00:59.756527 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/api/v1/authenticate
2025/07/19 19:00:59.941697 [TVE] action=wait_for_page
2025/07/19 19:00:59.968815 [TVE] action=request type=Document method=POST url=https://youtube.auth-gateway.net/saml/saml2/idp/SSOService.php
2025/07/19 19:00:59.968815 [TVE] action=auth_domain domain=youtube.auth-gateway.net
2025/07/19 19:01:00.027925 [TVE] action=response url=https://sp.auth.adobe.com/favicon.ico status=404 status_text=
2025/07/19 19:01:00.197254 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php redirected_from=https://youtube.auth-gateway.net/saml/saml2/idp/SSOService.php
2025/07/19 19:01:00.294929 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2025/07/19 19:01:00.395759 [TVE] action=request type=Document method=GET url=https://accounts.google.com/o/oauth2/auth redirected_from=https://youtube.auth-gateway.net/saml/module.php/authbypass/firstbookend.php
2025/07/19 19:01:01.154122 [TVE] action=error_response type=Other error=net::ERR_BLOCKED_BY_ORB url=https://csp.withgoogle.com/csp/frame-ancestors/a00d54fdef4a77536baac3725d1409f8 ip=142.250.113.141
2025/07/19 19:01:06.093640 [TVE] action=page_ready
2025/07/19 19:01:06.093640 [TVE] action=wait_for_page done=true reason=page_ready
2025/07/19 19:01:06.095064 [TVE] action=wait_for_auth timeout=24s
2025/07/19 19:01:06.095064 [TVE] action=fill_form u=[id]
2025/07/19 19:01:06.098164 [TVE] action=tvejs msg="googleLogin emailPicker"
2025/07/19 19:01:06.098164 [TVE] action=tvejs msg="googleAccountPicker"
2025/07/19 19:01:06.098164 [TVE] action=tvecmd src=google msg=wait
2025/07/19 19:01:06.098164 [TVE] action=retry_form
2025/07/19 19:01:06.407470 [TVE] action=request type=Document method=GET url=https://accounts.google.com/signin/oauth/consent
2025/07/19 19:01:06.408467 [TVE] action=interstitial
2025/07/19 19:01:06.577340 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authgoogle/linkback.php redirected_from=https://accounts.google.com/signin/oauth/consent
2025/07/19 19:01:07.284025 [TVE] action=fill_form state=done ignored=true err=&cdproto.Error{Code:-32000, Message:"Inspected target navigated or closed"}
2025/07/19 19:01:07.708197 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authSynacor/DiscoveryAssociationsResume.php
2025/07/19 19:01:07.790509 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/lastbookend.php redirected_from=https://youtube.auth-gateway.net/saml/module.php/authSynacor/DiscoveryAssociationsResume.php
2025/07/19 19:01:07.871415 [TVE] action=request type=Document method=GET url=https://youtube.auth-gateway.net/saml/module.php/authbypass/lastbookend.php
2025/07/19 19:01:08.045389 [TVE] action=request type=Document method=POST url=https://sp.auth.adobe.com/sp/saml/SAMLAssertionConsumer
2025/07/19 19:01:08.264376 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/completePassiveAuthentication redirected_from=https://sp.auth.adobe.com/sp/saml/SAMLAssertionConsumer
2025/07/19 19:01:08.264376 [TVE] action=authed
2025/07/19 19:01:08.266011 [TVE] action=cookies num_domains=2 num_cookies=7
Tried again with the actual Science channel, slightly different message:
2025/07/19 19:18:37.185967 [TVE] action=capture_html file=tve_error_screenshot.html size=60896
2025/07/19 19:18:37.515230 [WRN] discovery auth failed, trying again with sci: adobe auth reg code: Cable provider authentication failed
2025/07/19 19:18:25.117837 [TVE] action=fill_form u=[My userid here]
2025/07/19 19:18:33.180310 [HLS] Stopping transcoder session ch6110-dANY-ip127.0.0.1 (out=0s finished=false first_seq=0 last_seq=-1)
2025/07/19 19:18:37.119951 [TVE] action=check_result
2025/07/19 19:18:37.121885 [TVE] action=auth_timed_out
2025/07/19 19:18:37.121885 [TVE] action=screenshot
2025/07/19 19:18:37.179432 [TVE] action=screenshot file=tve_error_screenshot.png size=36301
2025/07/19 19:18:37.179935 [TVE] action=capture_html
2025/07/19 19:18:37.183434 [TVE] action=capture_html file=tve_error_screenshot.html size=60896
2025/07/19 19:18:37.183968 [TVE] action=capture_html
2025/07/19 19:18:38.876101 [TVE] action=version product=Chrome/138.0.7204.158 jsVersion=13.8.258.26 protocol=1.3 revision=@903c1a4e1274a274ac03d20a24ab16634d064418
2025/07/19 19:18:38.878076 [TVE] action=page_ready chromeVersion=138
2025/07/19 19:18:38.885976 [TVE] action=navigate url=https://sp.auth.adobe.com/api/v1/authenticate?reg_code=DUDXU4Y&mso_id=ATTOTT&domain_name=adobe.com&requestor_id=discovery&noflash=true&deviceType=html5&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2025/07/19 19:18:38.893834 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/api/v1/authenticate
2025/07/19 19:18:39.080877 [TVE] action=wait_for_page
2025/07/19 19:18:39.114341 [TVE] action=request type=Document method=POST url=https://api.cld.dtvce.com/idp/authn
2025/07/19 19:18:39.114341 [TVE] action=auth_domain domain=api.cld.dtvce.com
2025/07/19 19:18:39.172639 [TVE] action=response url=https://sp.auth.adobe.com/favicon.ico status=404 status_text=
2025/07/19 19:18:39.406526 [TVE] action=request type=Document method=GET url=https://identity.directv.com/weblogin/authorize redirected_from=https://api.cld.dtvce.com/idp/authn
2025/07/19 19:18:41.775157 [TVE] action=request type=Document method=GET url=https://identity.directv.com/weblogin/authenticate
2025/07/19 19:18:47.887639 [TVE] action=page_ready
2025/07/19 19:18:47.887639 [TVE] action=wait_for_page done=true reason=page_ready
2025/07/19 19:18:47.887639 [TVE] action=wait_for_auth timeout=12s
Instead of posting parts of the log you think are appropriate, just submit diagnostic logs.
You have multiple providers and what you posted is showing both YTTV and DIRECTV.
YTTV does not provide TVE access to Science network.
I do have a Source for YTTV but from years ago for a Free 7 day trial.(It worked!).
I'm afraid to Disable and for sure will not delete because some day I may switch to YTTV and I know of the issues with getting YTTV cranked up.
And yes you are correct sir, I should submit diagnostics but have only done that once a few years ago.
Because CDVR for me is VERY stable, this DTVstream issue is the first pblm I've ever had with that.
You can now disable a source from the DVR web UI Settings > Sources.
It just basically pauses it and will stop pulling guide data and disable streaming/recording for that sources channels.
You won't lose anything by disabling it. It can be re-enabled at any time.
Disabled.... If I have future YTTV problems... Men in Black will visit you
Bingo!!
They're back!
These devs are good
, they respond and fix.
Thank you.
I just updated to 2025.07.20.0706, deleted the existing tuner and added it back again, and everything is there. Thank you for fixing it quickly!
Trying to login to Direct TV Stream and keep getting this. Been trying for 2 days now. Any idea what the problem is?
There are some answers and suggestions to this problem in the following discussion:
Try now!!!
It's authenticating on my test server now.
I got it to work thank you for the heads up! Now just need to figure out why B1G and FS1-2 wonβt load, getting a reg_code error.
