Thanks, it looks like a Virtual Channels source is now appearing, how does this work?
I see that now I do have NBC back, how can I add ABC since I do show available at ABC Live Stream - ABC.com?
You would need to submit diagnostics and email support. On the dvr web UI under Support > Troubleshooting > Submit
Well I opened a support ticket and was told how to use Virtual Channels, no info on how to get ABC available via the thread at Experimental: Local Networks (NBC, ABC, FOX) in some major metros via TVE any ideas?
Anyone else having issues with Dish not authenticating?
Anyone having issues with Fox News maintaining a constant stream? Mine times out after 2 minutes. Other channels are fine.
2022/06/29 16:05:54.229712 [TNR] Opened connection to TVE-Dish for ch6073 FNC
2022/06/29 16:05:54.229819 [DVR] Recording for job 1656536220-11 from TVE-Dish ch6073 into "TV/The Five/The Five 2022-06-29-1557.mpg" for 57m10.423971s
2022/06/29 16:10:20.848798 [TNR] Cancelling stream TVE-Dish ch6073 after no data was received for 2m0s
2022/06/29 16:10:20.947429 [MTS] Statistics for "TV/The Five/The Five 2022-06-29-1557.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=0 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=true saw_pmt=true highest_pts=631.980711
2022/06/29 16:10:49.445033 [TNR] Closed connection to TVE-Dish for ch6073 FNC
2022/06/29 16:10:49.445126 [DVR] Job 1656536220-11 The Five ended prematurely: 52m10.554879s
I'm getting "Cable provider authentication failed Unhandled exception" when I try to login with Dish credentials...I know I'm using the correct credentials as I can login directly to the Dish site with them.
Help? It feels like there's just a brick wall of what to try next.
Submit diagnostics and email support
Anyone here still using Dish TVE with Channels DVR successfully? Channel list from thread history still about accurate?
