Provider - FuboTV
Anyone else having issues with Fubo TVE logins for CBS Sports and Fox Sports?
I just tried to tune into both and got "Not Authorized". I tried rescanning the channels, and all are showing as "Not Authorized" now. I can login to both CBS Sports and Fox Sports and use my Fubo credentials to watch online. Please help. No entries in the logs after scanning, just "Not Authorized" in the edit screen.
Thanks.
When that happened to me I had to remove Fubo as a source and readd it. Everything came back. No promise it will work for you, but it worked for me.
Thanks @boogmeister1, that seemed to do the trick.
I am unable to add FuboTV as a provider. It just sits at the "Verifying login on FuboTV" for over an hour. Very disappointed. Any work arounds?
Email support@getchannels.com with the messages from the Log tab
Sent. Thank you.
Problem has been resolved. Was using an ancient version of Google Chrome. Thank you support for solving my problem quickly.
I can't login using my Shield DVR. Basically it times out and doesn't authenticate.
EDIT:
Devs released a new DVR which fixed it.
Version: 2020.03.09.1921
We would like to get to the bottom of this. If someone can share logs from when this happens along with their settings.db please send to support@getchannels.com
I would love to help, but I no longer have fubo. I have switched to YouTube tv.
If it happens to me I will let you know.
This just started happening:
2020/03/14 15:04:26.510921 [SYS] Created database snapshot: backup-20200314.150426
2020/03/14 15:04:26.775753 [SYS] Removing old backup backup-20200220.004110
2020/03/14 15:37:41.600573 [ERR] Error during stream TVE-Fubo ch6073 FNC: Failed to download file: https://x-live-fox-stgec.uplynk.com/ausw/slices/27a/4f59ea65df184a2580ad8fc80d3eaa32/27aaeb9d311e43a89e1e1c4b17efadd1/A00000000.ts?pbs=d86f64ce7cfd456f834ccb25e0e3251f&_jt=l&chid=1e298c9d65a245b3bd37f339cadcca58&oid=5b6fd7c6528d417e8bdad7f79754bb9e&si=77: 403 Forbidden
2020/03/14 15:37:41.700273 [TNR] Closed connection to TVE-Fubo for ch6073 FNC
2020/03/14 15:39:16.543849 [TVE] stream timestamps: fnc: start_at=2020-03-14T15:39:14-04:00 current_at=2020-03-14T15:39:41-04:00 end_at=2020-03-14T15:39:45-04:00
2020/03/14 15:39:16.543983 [TNR] Opened connection to TVE-Fubo for ch6073 FNC [transcode=none]
2020/03/14 15:39:41.936549 [ERR] Error during stream TVE-Fubo ch6073 FNC: Failed to download file: https://x-live-fox-stgec.uplynk.com/ausw/slices/27a/4f59ea65df184a2580ad8fc80d3eaa32/27aaeb9d311e43a89e1e1c4b17efadd1/A00000000.ts?pbs=2699dd12767f4cb78466e5c041c02bee&_jt=l&chid=1e298c9d65a245b3bd37f339cadcca58&oid=5b6fd7c6528d417e8bdad7f79754bb9e&si=1: 403 Forbidden
2020/03/14 15:39:42.050801 [TNR] Closed connection to TVE-Fubo for ch6073 FNC
2020/03/14 15:39:51.449935 [TVE] stream timestamps: fnc: start_at=2020-03-14T15:39:51-04:00 current_at=2020-03-14T15:40:17-04:00 end_at=2020-03-14T15:40:21-04:00
2020/03/14 15:39:51.450041 [TNR] Opened connection to TVE-Fubo for ch6073 FNC [transcode=none]
2020/03/14 15:43:10.617922 [TNR] Closed connection to TVE-Fubo for ch6073 FNC
2020/03/14 15:43:12.695467 [TVE] stream timestamps: fnc: start_at=2020-03-14T15:43:12-04:00 current_at=2020-03-14T15:43:32-04:00 end_at=2020-03-14T15:43:41-04:00
2020/03/14 15:43:12.695581 [TNR] Opened connection to TVE-Fubo for ch6073 FNC [transcode=none]
2020/03/14 15:47:38.054842 [ERR] Error during stream TVE-Fubo ch6073 FNC: Failed to download file: https://x-live-fox-stgec.uplynk.com/ausw/slices/27a/4f59ea65df184a2580ad8fc80d3eaa32/27aaeb9d311e43a89e1e1c4b17efadd1/A00000000.ts?pbs=eb61a31f380943d9a63bd708458d0b3c&_jt=l&chid=1e298c9d65a245b3bd37f339cadcca58&oid=5b6fd7c6528d417e8bdad7f79754bb9e&si=2: 403 Forbidden
2020/03/14 15:47:38.131410 [TNR] Closed connection to TVE-Fubo for ch6073 FNC
Had a similar issue. Logs have been sent to support...
403 Forbidden means that there was an authentication issue, most likely because there are issues in their end.
This been happening on many TVE stations as of late...no matter the Provider Credentials used.
EDit: it is stated by devs 403 error is a regional issue with TVE, and it matter not what TVE provider is used.
Edit 2: so...2 separate issues related to TVE and 403 error.
see here.
not true, i have zero problems with my optimum and verizon credentials. its been chugging along like a champ for months.
Is true, and the proof is on the fourms.
Same channels, tested using Philo, Xfinity, Fubo, YT. TVE logins
Users with these and more have posted and reported the same TVE stream issue of 403 forbidden when commercial break happens.
SOme have reported that the live stream in the networks own app also has issues to, leading to the statement that its the source error, not anything to do with channels.
However, I have streamed Discovery and CC for over 2hrs via their app with no issues, so i still think it is an issue with Channels at least in some fashion.
The stream is from one source, no matter the credentials, so if that has issue, then it affect everything.
The devs already stated that.
Good for you that you are not having issues. U may have different issue then.
Bur for many, stations like Discovery, DIY, Comedy Central, etc are very hard to watch due to the issue.
im not saying people dont have problems, im saying that not everyone has those problems like you eluded to. i dont have any problems, even though we are all getting the streams from one source.
since we all use the same source, no matter the credentials, and i and probably others have no issues, maybe its another problem.
a network problem? i have a good business class Ubiquiti router/switches/access points network. maybe thats it.
maybe its the dns servers you use? who knows.
my server is on a windows box, not a shield, or other "low powered" device. maybe thats it.
or maybe cable credentials work better than streaming services on their back end, thats a possibility.
This seems like the most reasonable answer to these issues, especially since the problem with streams are with dotted with 403 Forbidden errors when tying to access parts of the stream.
