Provider - Philo
Philo just sent out notice yesterday that AXS and HD Net (in a sub package) are no longer available starting August 1st.
Looks like you wil need to either use Sling or something else.
AXS and HDNET aren't on TVE.
Both HDNET and AXS are in the Value Channels at FreeCast+. Looks like an app that's a work in progress.. FreeCast has a DVR for the Value Channels only. While those two channels never had TVE in my Philo scans, there has been an addition to my Philo TVE in Channels in the past week, it now includes Mystery Alley from Ovation. I assume that is coming to the Philo app line up, it's not on the app as of today.
At this point, we only have two options
option 1 use ADB Tuner to physically use the app providing it has deep linking
or find out the stream URLs and maybe have someone build a docker for use in Channels.
We will have to see.
I'm using ADB Tune with an Onn Box and my Philo subscription.
You can get the required HDMI encoder for as little as $80.00 and the Walmart box for about $20.00
ti would be nice to know if Freecast su[sorts Deep linking.
Can anyone confirm using PHiLO as provider you can stream, see CatchyTV (comedy)?
Thx
I don't even see such a channel by that name. Do you have channel number?
Catchy is not available as a TVE stream and thus not available via Channels.
You can use ChromeCapture or ADB Tuner:. The URL:
https://www.philo.com/player/player/channel/Q2hhbm5lbDo2MDg1NDg4OTk2NDg0Mzk2OTU
could one set up a stream link? perhaps?
Philo is DRM'd
Catchy Comedy is available thru Frndly TV. See Frndly TV for Channels for how to set-up and use with Channels DVR.
if you use the FRNDLY TV project, the better picture quality will be had for that and some other channels.
I have philo setup to get all the discovery and TVE available.
I have FRNDLY passing along the stuff not on TVE.
I have ADB Tuner with a couple of ONN boxes grabbing stuff from Philo and Hulu plus live TV.
If I can watch a channel through the TVE or FRNDLY
project, I will use those sources first because it looks better.
thanks
Does HDNET have a screen bug on the bottom right of the screen through every provider, or just Freecast?
Sounds like you're paying way more than just getting cable lol
Yep by the Time you get everything you want with different subscribers Cable looks like a bargain..
Just added Philo as a source. Problem the channels are all wrong. None are the correct channels looks like all the free ones, none of the right ones. Is Philo now DRM?
No. Try verifying your credentials are right and add philo source again.
Thanks but I deleted Philo and added it back. Still did not work.
Tried a rescan got this error:
A Javascript error has occurred!
Please refresh the browser after reporting this issue on Channels Community or to [email protected].
Cannot read properties of undefined (reading '$$typeof')
l4.showModal@http://127.0.0.1:8089/admin/globals.jsx:381
b.@http://127.0.0.1:8089/admin/components/DeviceChannelsModal.jsx:101
G71@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:131
Eg@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:220
Yi@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:259
b@http://127.0.0.1:8089/node_modules/scheduler/cjs/scheduler.production.min.js:18
Nf@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:122
gg@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:252
Uj@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:243
c@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:123
Visit this url and see if you have an error screenshot. Post it if there is one.
http://your.server.ip:8089/providers/tve/error_screenshot.png
Do you get all green checks under dvr ui > support > troubleshooting
