I am unable to authenticate my Xfinity account via Channels - I keep on getting an error with a screenshot of a login page. I'm using a sub-account without 2FA. Any thoughts? I've updated to the latest pre-release version as part of my troubleshoot.
Can you watch your local NBC station here using the same username and passowrd?
Yup, no issues on the NBC stream through their website with Xfinity login or on the xfinity stream site.
EDIT: My Channels server is installed on a QNAP NAS. For troubleshooting, I just tried installing the server on Windows and adding Xfinity TVE worked, so looks like the NAS installation is the issue.
Try the Troubleshooting menu selection on the NAS and see if it shows any errors.
DVR web admin Support > Troubleshooting
All green checkmarks
I also disabled the QNAP firewall and antivirus in case they were interfering, no luck.
My suggestion, if you want it on the QNAP, is to click the Submit Diagnostic Logs button at the bottom of that Troubleshooting page so the developers can help you.
Will do -- thank you!!
Exact same issue as @sumothergup - using account without 2FA, streaming works fine when directly logging in to any of the services, error is a screenshot of a login page. I'm using channels on Synology - tried via both Safari and Chrome, no difference. In my case, it was an addblocker running on my router (eero) - disabling the addblocker fixed the login. If you look in the logs (excerpt below) you can see some of the sites being blocked - in case you have the same problem.
2022/09/14 10:09:26.218553 [TVE] action=retry_form
2022/09/14 10:09:26.401279 [TVE] action=wait_for_auth
2022/09/14 10:09:26.414467 [TVE] action=request type=Document method=POST url=https://login.xfinity.com/login
2022/09/14 10:09:26.495909 [TVE] action=error_response type=Image error=net::ERR_NAME_NOT_RESOLVED url=https://googleads.g.doubleclick.net/pagead/viewthroughconversion/1023869955/
2022/09/14 10:09:26.640978 [TVE] action=error_response type=Script error=net::ERR_NAME_NOT_RESOLVED url=https://scripts.webcontentassessor.com/scripts/e5d00e87ba3bf67af60bbc75377626fb1f0b0a10c2e83ca40b7a245ca2cd8367
2022/09/14 10:09:26.684876 [TVE] action=error_response type=Image error=net::ERR_NAME_NOT_RESOLVED url=https://7468.v.fwmrm.net/ad/u
2022/09/14 10:09:27.060668 [TVE] action=error_response type=Document error=net::ERR_NAME_NOT_RESOLVED url=https://secure.adnxs.com/tt
2022/09/14 10:09:27.713542 [TVE] action=error_response type=Image error=net::ERR_NAME_NOT_RESOLVED url=https://googleads.g.doubleclick.net/pagead/viewthroughconversion/1023869955/
2022/09/14 10:09:32.399525 [TVE] action=page_ready
2022/09/14 10:09:32.399613 [TVE] action=retry_form step=auth_form count=3
2022/09/14 10:09:33.071283 [TVE] action=fill_form u=[ my xfinity login id ]
2022/09/14 10:09:33.073136 [TVE] action=tvejs msg="xfinityLogin: wait"
I'm unable to get Xfinity Authenticated. I'm able to log into my Xfinity Account online and log into the different network stations apps/websites just fine.
This is what it looks like when attempting to log in.
And these are the http request logs of the sequence happening
2022/09/17 07:14:59.865167 [TVE] action=fill_form u=*[UserNameHere]*
2022/09/17 07:14:59.868521 [TVE] action=tvejs msg="xfinityLogin: wait"
2022/09/17 07:14:59.868562 [TVE] action=retry_form
2022/09/17 07:15:00.006729 [TVE] action=wait_for_auth timeout=24s
2022/09/17 07:15:00.014979 [TVE] action=request type=Document method=POST url=https://login.xfinity.com/login
2022/09/17 07:15:06.267929 [TVE] action=page_ready
2022/09/17 07:15:06.268027 [TVE] action=retry_form step=auth_form count=2
2022/09/17 07:15:06.783061 [TVE] action=fill_form u=*[UserNameHere]*
2022/09/17 07:15:06.786458 [TVE] action=tvejs msg="xfinityLogin: wait"
2022/09/17 07:15:06.786496 [TVE] action=retry_form
2022/09/17 07:15:06.981740 [TVE] action=wait_for_auth timeout=24s
2022/09/17 07:15:06.992073 [TVE] action=request type=Document method=POST url=https://login.xfinity.com/login
2022/09/17 07:15:07.333066 [TVE] action=error_response type=Image error=net::ERR_ABORTED url=https://www.google.com/pagead/1p-user-list/1023869955/
2022/09/17 07:15:13.259118 [TVE] action=page_ready
2022/09/17 07:15:13.259182 [TVE] action=retry_form step=auth_form count=3
2022/09/17 07:15:14.174024 [TVE] action=fill_form u=*[UserNameHere]*
2022/09/17 07:15:14.177362 [TVE] action=tvejs msg="xfinityLogin: wait"
2022/09/17 07:15:14.177401 [TVE] action=retry_form
2022/09/17 07:15:14.318536 [TVE] action=wait_for_auth timeout=24s
2022/09/17 07:15:14.328073 [TVE] action=request type=Document method=POST url=https://login.xfinity.com/login
2022/09/17 07:15:20.535048 [TVE] action=page_ready
2022/09/17 07:15:20.535112 [TVE] action=retry_form_failed
2022/09/17 07:15:20.535136 [TVE] action=screenshot
2022/09/17 07:15:20.616636 [TVE] action=screenshot size=36897
2022/09/17 07:15:20.616884 [TVE] action=capture_html
2022/09/17 07:15:20.623446 [TVE] action=capture_html size=115426
When going to URL_https://login.xfinity.com/login" manually I am able to log in & authenticate my account.
These are the diagnostic logs of this login attempt. cb05acb1-53aa-49ea-b52b-534450404793
Edit: I also just attempted to delete the contents of the chrome data folder to no availe
Hello! I frequently have channel issues where I lose some channels or have to rescan them all and it doesn't pick them all up, and have found that firing up the VPN provides the best results for an all channel scan, and individual scans. It'll pull in different locals, so disable the VPN and individual scan the locals. I don't know if this will help with the login issues.
I'm in the same boat. I also have Xfinity TVE. I'm getting lots of timeouts just like this log. @tmm1 - Any ideas? Thanks!
Logs:
f411515b-7d92-40a2-b95e-ed122e7405ab
Same issue here. Cable provider authentication failed
Gave up after trying everything I could think of for two days (except for clockwise rotating handstands).
Ended up with 3 locals and 7 Fox network channels.
Everything else except the free channels errored out.
I'm thinking the Xfinity auth system is broken.
And today it decided to work. All channels came back.
Many channels are authorizing for me today as well, but still many are timing out. I’ve had some success authenticating individually, but still can’t authenticate most of the sports channels. All the ESPNs, NBC Sports etc. they have all authenticated in the past.
I gave up trying to force things as I just get frustrated. If it doesn't work and I'm on the latest pre-release, I just wait a day and try again. Try to individually rescan the missing channels tomorrow.
I'm trying get a new user logged in & it appears its not even able to get the username into the form. Which is what my screenshot would indicate.
Literally nothing is authenticating for me. Its very frustrating.
Happened to me 3 or 4 times recently.
After getting frustrated when nothing I did worked, I walked away.
The next day it worked.
Go figure.
Its super frustrating, it's been over a week for me now with no fix in sight.
I usually mess with it for a day or two, make sure I'm at the latest pre-release, submit diagnotics and wait another day. Believe me, I try everything in my troubleshooting list TVE Troubleshooting tips and then some. It is frustrating, escpecially if TVE is your only source. I've learned not to rely on it as my only source and sleep better.
