Question about Extras and Local Content
When importing your movies and tv shows into Channels, can your extras from the movie/tv show be added or seen within the specific movie/tv show screen? I would love to see Season and Episode extras (commentaries, deleted scenes) to be able to be watched from a tv show in Channels.
The o my movie extras supported are sidecar trailers and subtitle files.
Tv extras are supported. Group them within a season using 0 as their episode number. Group them with the show over all using 0 for their season number.
Thanks. I know Plex can do episode-specific extras which are located under the episode of a specific season. For example, episode 1 of season 1 has the episode and underneath it will have commentary or deleted scene. Naming as follows:
Seinfeld S01.E01-Pilot
Seinfeld S01.E01-Audio Commentary-Featurette
Seinfeld S01.E01-Deleted Scene
Will additional movie extras (commentaries, deleted scenes) be able to be added for movies in the future?
At some point. A lot goes into handling things like this. Data wise, it’s simple, presentation wise it is not.
Thanks Maddox. I am sure it is not an easy or simple process but really hope things like this is added for a more immersive experience.
Movie extras have entered beta on tvOS and iOS and you can learn about them here:
