Recording E+TV
I have a docker container set up with E+TV using it as a custom channel on the server. I am able to view the channels using the apps, however, I cannot record the channel or view in a web browser. This did work previously. I cannot specify the specific versions that it worked with. Just wondering if anyone else uses E+TV and what your experience is. Getting an error stating the media could not be loaded, either because the server or network failed or because the format is not supported.
A post was merged into an existing topic: ESPN+ & FOX Sports with Custom Channels via EPlusTV
