I meant this display from the grid guide
Set your Timezone correctly in your docker container. You're not in UTC time.
That would account for Sundays airing being selected when you ask for Monday.
And you're not using the latest docker container image fancybits/channels-dvr - Docker Image
good catch, but it is something to do with channels and the episode number.
I finally caught my setup doing the same thing
That's because you have two sources, Paramount and CBS.
Paramount airs the episodes before CBS.
lol
Ok, I updated my Portainer stack for Channels DVR to EDT, as UTC did seem odd when I posted my server stats. No clue where the timezone variable went 4 months ago.
However, Sunday is gone from the Monday filter criteria, but it still doesn't queue it for recording.
You may have to delete and recreate the guide database again.
That was after I did. It fully recreated now and everything set to record except Mondays as before.
Pause and Resume the pass.
What does the pass criteria look like now.
I just added a contains pm to mine and there was some weirdness like showing the am recording, but not queued, ect.. until i did a ctrl-f5 on /admin/dvr/rules
Pause and resume yielded no change.
What does the advanced pass look like now.
And is the grid guide still showing an airing on channel 106.1 for Monday at 7:30PM?
It was chamnel 106.1 and Monday that had the 2 airings for Monday, but not queued.
I gave up on it and set it to recprd as usual without the Monday episodes. I appreciate the help. Going to sleep for now, but I'll try mjitkop"s suggestion tomorrow to see if I can force the recordings in.
OK.
Just figured since you had the Timezone wrong that the airing times might be different now that it's set correctly.
