I have a block of static public IP addresses with my AT&T Fiber service. I hand them out via 1:1 NAT on my pfsense firewall. For various reasons, I have one assigned to the desktop pc running Channels DVR. This has seemed to cause a decent amount of instability with remote access. Sometimes it works, other times it does not.
When I go to the troubleshooting page, remote access has a yellow triangle with an exclamation point and says:
Outgoing connections are coming from (The 1:1 NAT assigned public IP) but the external IP of the router is (Firewall's main external IP)
Every time I am away and the Channels DVR app says it cannot connect, I can browse to the 1:1 NAT IP address using port 8089
Any other application and website I've used only sees and cares about the assigned 1:1 NAT IP address and doesn't see or doesn't care about the firewall's external IP.
What can I do to get it so remote access is stable with this configuration?
