Recently I noticed when using my sofabaton u2 remote to skip a page in the guide (channel down) it skips ahead in time in addition to skipping a page of channels. it does not do this when I use my stock remote. I am wondering if this is a new bug or should I remap that button. if so to what. thanks.
fyi button is mapped to "pagedown" I tried mapping it to channeldown but when I press the button nothing happens.I forgot to mention I am using an onn pro with the latest firmware and the beta version of the channels app.
bump
Just tested a usb keyboard with my onn pro and pressing pagedown causes the epg to jump ahead a few hours aswell. It should not do this. Instead it should show the next page of channels.
What version number is shown in the app
I am on app version 4.9.3 thanks.
Was just going to post on the same topic. Nvidia Shield with Sofabaton. I also have a wireless keyboard and get the same error. The server version shows as 2025.06.01.2212 and the client version shows as 4.9.3.
Thanks for confirming the bug.
any progress on this? thanks.
I don't see it skipping ahead in time.
I did see it skip backwards in time if you're scrolled ahead and click page down.
odd. for me when I press page down it skips ahead by 1 hr. are you testing using an onn pro with the latest firmware? thanks.
bump
I have been busy for a few days but am back. Is there any update on this? thanks.
Is anyone there???
When there is something new to report you will see it posted here.
If you have more details to share you can post those but otherwise pinging every day is not helpful.
understood, keep in mind this bug is really affecting my family's ability to watch tv and they are bugging me every day.
Possible fix in beta
No dice it still jumps ahead.
Why was this released as stable when it is not fixed.
The page up/down change is not in the stable release.
