Samsung TV Plus for Channels
I'm seeing the same thing on the same sources - no guide data for Samsung.
should be back now. my automation was failing to connect to the vpn.
have switched them all over to more reliable wireguard connections now so should be better going forward
Getting a 404 from https://i.mjh.nz/PlutoTV/us.xml
Been working for me since he posted.
The EPG for Plex has not been updated since April 3,
I'm very close to scrapping Plex. Their api sucks
UPDATE:
Back working now :slight_smile:
Your are awesome!! :purple_heart:
Seriously, awesome. Thank you so much @matthuisman!
would be really cool to implement a container that allows people to use their own token and generate a device id for use in the m3u URLs
Curious , is there not an au version of the Samsung channels listings.
Great job, @matthuisman!
I already have a monthly donation set up in PayPal to you because I'm using Frndly for Channels.
Since I'm also using PLEX and Samsung TV in Channels, I will increase my donation for your great support.
Thank you!
Looks like Samsung has one.
https://www.techguide.com.au/news/televisions-news/samsung-tv-plus-quietly-launches-in-australia-with-30-free-channels
69 channels listed here
i use the android apps api to generate the playlists.
So only support Samsung TV Plus where their android app is supported
Thanks
Thanks
Got ya I was wondering how the guide for au.
Anyway to get guide data further out for Samsung TV Plus?
@matthuisman Matt, I'm not getting guide data for your US Plex channels again. I even deleted and recreated my whole guide database, but this is the only m3u that won't load guide data again. https://i.mjh.nz/Plex/us.xml
Also reported here
Anyone else lost their Samsung TV+ listings in the last couple of days?
