I’ve been noticing an issue with the shake to mute feature and I wondered if it was a bug or if it’s something I’m doing wrong.
I have two ATVs (one 4K, one 4G–both on 11.4.x) that are now exhibiting the same issue. It will usually happen when content is time shifted and I’ll either mute on purpose, or by an accidental shake of the remote. I will be able to shake the remote to unmute and the sound won’t return. Another shake will mute (on screen indicator) and yet another shake will unmute (indicator will disappear), but no sound can be heard. At some point, the shaking will not unmute (on screen indicator remains) and I will have to close the app and restart it.
At this point, I will just turn down the volume to be able to time shift content and still be able to hear it. Does anyone know if this is a known feature? Is there something that I can do (reinstall, power cycle, etc.) to avoid it from happening? Thanks!
