@tmm1, what do you make of this error log? All my recordings didn't record today and they show as still queued up even thought the times are now in the past:
2019/09/06 17:33:36 [DVR] Error running job 1567826940-37 House Hunters: could not start stream on channels=[6104]: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-119001662: read-only file system
2019/09/06 17:34:07 [DVR] Starting job 1567826940-37 House Hunters on ch=[6104]
2019/09/06 17:34:07 [DVR] Waiting 4h24m52.946025203s until next job 1567843140-23 Hawaii News Now at 10:00
2019/09/06 17:34:07 [ERR] Failed to start stream on channel 6104 via TVE-Comcast_SSO: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-867155077: read-only file system
2019/09/06 17:34:07 [ERR] Failed to start stream on channel 6104 via TVE-sony_auth-gateway_net: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-457750048: read-only file system
2019/09/06 17:34:07 [DVR] Error running job 1567826940-37 House Hunters: could not start stream on channels=[6104]: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-457750048: read-only file system
2019/09/06 17:34:37 [DVR] Starting job 1567826940-37 House Hunters on ch=[6104]
2019/09/06 17:34:37 [DVR] Waiting 4h24m22.45316985s until next job 1567843140-23 Hawaii News Now at 10:00
2019/09/06 17:34:37 [ERR] Failed to start stream on channel 6104 via TVE-Comcast_SSO: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-998340351: read-only file system
2019/09/06 17:34:37 [ERR] Failed to start stream on channel 6104 via TVE-sony_auth-gateway_net: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-985124434: read-only file system
2019/09/06 17:34:37 [DVR] Error running job 1567826940-37 House Hunters: could not start stream on channels=[6104]: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-985124434: read-only file system
2019/09/06 17:35:07 [DVR] Starting job 1567826940-37 House Hunters on ch=[6104]
2019/09/06 17:35:07 [DVR] Waiting 4h23m52.419327154s until next job 1567843140-23 Hawaii News Now at 10:00
2019/09/06 17:35:07 [ERR] Failed to start stream on channel 6104 via TVE-Comcast_SSO: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-122903433: read-only file system
2019/09/06 17:35:08 [ERR] Failed to start stream on channel 6104 via TVE-sony_auth-gateway_net: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-263442772: read-only file system
2019/09/06 17:35:08 [DVR] Error running job 1567826940-37 House Hunters: could not start stream on channels=[6104]: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-263442772: read-only file system
2019/09/06 17:35:38 [DVR] Starting job 1567826940-37 House Hunters on ch=[6104]
2019/09/06 17:35:38 [DVR] Waiting 4h23m21.781096124s until next job 1567843140-23 Hawaii News Now at 10:00
2019/09/06 17:35:38 [ERR] Failed to start stream on channel 6104 via TVE-Comcast_SSO: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-731515043: read-only file system
2019/09/06 17:35:38 [ERR] Failed to start stream on channel 6104 via TVE-sony_auth-gateway_net: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-401971110: read-only file system
2019/09/06 17:35:38 [DVR] Error running job 1567826940-37 House Hunters: could not start stream on channels=[6104]: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-401971110: read-only file system
2019/09/06 17:36:08 [DVR] Skipping job because program already started 1567826940-37 House Hunters
2019/09/06 17:36:08 [DVR] Waiting 4h22m51.706271343s until next job 1567843140-23 Hawaii News Now at 10:00
2019/09/06 18:01:06 [NAT] Successfully mapped port 8089 using natpmp
2019/09/06 18:37:00 [TNR] Opened connection to 10765FA3 for ch10.1 KMEB-HD
2019/09/06 18:37:00 [HLS] Starting transcoder for channel 10.1 from 192.168.1.61 (encoder=h264_mediacodecndk, resolution=1080, deinterlacer=blend, bitrate=8000)
Could not write header for output file #0 (incorrect codec parameters ?): No such file or directory
Error initializing output stream 0:0 --
2019/09/06 18:37:18 [WRN] Buffer for 10765FA3 ch10.1 is more than 50% full (clients=1, len=16777684)
2019/09/06 18:37:24 [WRN] Buffer for 10765FA3 ch10.1 is more than 75% full (clients=1, len=25166000)
2019/09/06 18:37:29 [WRN] Buffer for 10765FA3 ch10.1 is more than 95% full (clients=1, len=31877468)
2019/09/06 18:37:29 [WRN] Buffer for 10765FA3 ch10.1 is more than 99% full (clients=1, len=33219788)
2019/09/06 18:38:42 [HLS] Stopping inactive session ch10.1-dANY-ip192.168.1.61 @ 0s
2019/09/06 18:38:42 [TNR] Closed connection to 10765FA3 for ch10.1 KMEB-HD
2019/09/06 18:42:24 [ERR] Could not start stream for TVE-Spectrum ch6023 PARAMOUNTP: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-495569613: read-only file system
2019/09/06 18:42:38 [ERR] Could not start stream for TVE-Spectrum ch6021 TVLANDP: TVE: mkdir /storage/emulated/0/Streaming/channels-cache-900080584: read-only file system
2019/09/06 18:49:49 http: TLS handshake error from 192.168.1.46:56723: remote error: tls: unknown certificate
2019/09/06 18:49:49 http: TLS handshake error from 192.168.1.46:56725: remote error: tls: unknown certificate
2019/09/06 18:49:51 http: TLS handshake error from 192.168.1.46:56727: remote error: tls: unknown certificate
2019/09/06 18:49:51 http: TLS handshake error from 192.168.1.46:56729: remote error: tls: unknown certificate
2019/09/06 18:49:56 http: TLS handshake error from 192.168.1.46:56732: remote error: tls: unknown certificate
2019/09/06 18:49:59 http: TLS handshake error from 192.168.1.46:56739: remote error: tls: unknown certificate
2019/09/06 18:50:05 http: TLS handshake error from 192.168.1.46:56744: remote error: tls: unknown certificate
2019/09/06 18:50:06 http: TLS handshake error from 192.168.1.46:56749: remote error: tls: unknown certificate
2019/09/06 18:50:06 http: TLS handshake error from 192.168.1.46:56751: remote error: tls: unknown certificate
2019/09/06 18:50:06 http: TLS handshake error from 192.168.1.46:56750: remote error: tls: unknown certificate
2019/09/06 18:50:06 http: TLS handshake error from 192.168.1.46:56752: remote error: tls: unknown certificate
2019/09/06 18:50:06 http: TLS handshake error from 192.168.1.46:56753: remote error: tls: unknown certificate
2019/09/06 18:50:06 http: TLS handshake error from 192.168.1.46:56758: remote error: tls: unknown certificate
2019/09/06 18:50:22 http: TLS handshake error from 192.168.1.46:56760: remote error: tls: unknown certificate
2019/09/06 18:50:23 http: TLS handshake error from 192.168.1.46:56765: remote error: tls: unknown certificate
2019/09/06 18:50:23 http: TLS handshake error from 192.168.1.46:56766: remote error: tls: unknown certificate
2019/09/06 18:50:23 http: TLS handshake error from 192.168.1.46:56767: remote error: tls: unknown certificate
2019/09/06 18:50:23 http: TLS handshake error from 192.168.1.46:56768: remote error: tls: unknown certificate
2019/09/06 18:50:23 http: TLS handshake error from 192.168.1.46:56769: remote error: tls: unknown certificate
2019/09/06 18:50:23 http: TLS handshake error from 192.168.1.46:56770: remote error: tls: unknown certificate
2019/09/06 18:50:23 http: TLS handshake error from 192.168.1.46:56771: remote error: tls: unknown certificate
2019/09/06 18:50:23 http: TLS handshake error from 192.168.1.46:56776: remote error: tls: unknown certificate
2019/09/06 18:50:34 http: TLS handshake error from 192.168.1.46:56788: remote error: tls: unknown certificate
2019/09/06 18:53:36 http: TLS handshake error from 192.168.1.46:56803: remote error: tls: unknown certificate
2019/09/06 18:53:36 http: TLS handshake error from 192.168.1.46:56804: remote error: tls: unknown certificate
2019/09/06 18:53:36 http: TLS handshake error from 192.168.1.46:56806: remote error: tls: unknown certificate
2019/09/06 18:53:36 http: TLS handshake error from 192.168.1.46:56809: remote error: tls: unknown certificate
2019/09/06 18:53:36 http: TLS handshake error from 192.168.1.46:56810: remote error: tls: unknown certificate
2019/09/06 18:53:36 http: TLS handshake error from 192.168.1.46:56811: remote error: tls: unknown certificate
2019/09/06 18:53:36 http: TLS handshake error from 192.168.1.46:56812: remote error: tls: unknown certificate
2019/09/06 18:54:00 http: TLS handshake error from 192.168.1.46:56817: remote error: tls: unknown certificate
2019/09/06 18:54:00 http: TLS handshake error from 192.168.1.46:56820: remote error: tls: unknown certificate
2019/09/06 18:54:00 http: TLS handshake error from 192.168.1.46:56819: remote error: tls: unknown certificate
2019/09/06 18:54:10 http: TLS handshake error from 192.168.1.46:56826: remote error: tls: unknown certificate
2019/09/06 18:54:10 http: TLS handshake error from 192.168.1.46:56828: remote error: tls: unknown certificate
2019/09/06 18:54:10 http: TLS handshake error from 192.168.1.46:56829: remote error: tls: unknown certificate
2019/09/06 18:56:09 http: TLS handshake error from 192.168.1.46:56992: remote error: tls: unknown certificate
2019/09/06 18:56:09 http: TLS handshake error from 192.168.1.46:56997: remote error: tls: unknown certificate
2019/09/06 18:56:09 http: TLS handshake error from 192.168.1.46:56999: remote error: tls: unknown certificate
2019/09/06 19:00:13 http: TLS handshake error from 192.168.1.46:57053: remote error: tls: unknown certificate
2019/09/06 19:00:13 http: TLS handshake error from 192.168.1.46:57055: remote error: tls: unknown certificate
2019/09/06 19:01:06 [NAT] Successfully mapped port 8089 using natpmp
2019/09/06 19:02:18 http: TLS handshake error from 192.168.1.46:57064: remote error: tls: unknown certificate
There are more of the same above the top, so I didn't send those since they're redundant.
