Hello, I'm still loving this "hack." It is working so well. It's terrific to have bonus channels to mix in with the rest. Thanks again to Robbiet480 for coding it.
As I understand it- which is borderline barely- this docker container is based on the Pluto one... which is also fantastic. I have both running on Synology NAS hardware.
One peculiar difference is that this one seems to have a rolling "local port." Every day or two, the location of the EPG rolls +3-8 more port numbers from where it was last. For example, if local port is 32800 today, within a day or two it is going to be 32805 or so. And a few days later, it will be 32811 or so. The Pluto container doesn't do this. It is "at" the same Local Port for many weeks since I installed it.
Why does this matter? Local Port points to the EPG. So when it changes, it seems the EPG will not update until I go in and change the Port Number to the new one in Channels Settings.
Any way to make this part of things work like the Pluto container- that is, consistently stick with a port number? What I think is happening is that this container is restarting every day or two (maybe updates every day or two). The last one is showing it has been running for 4 hours and port number is different than it was yesterday. The Pluto container right above shows it has been running for 41 days.
If anyone has a solution I can apply, I'd welcome a for-dummies, step-by-step to do whatever needs to be done. Else, if this is simply an evolving program that is updated regularly and thus this port number will need to keep updating until the code is fully perfected, I'll keep rolling with manually updating port numbers for EPG calls in Channels settings.
Thanks for any help if there's anything I can do.
