The Stirr Channel Logos and Poster art are so small you can hardly see them. Pluto is perfect , anyone have any thoughts?
Garbage in, garbage out.
It seems the source you’re using has really insanely tiny logos and no guide art either.
You’ll want to figure out how to make the logos better when feeding it to Channels.
Using what you provided via Docker ... maybe someone else has the issue and can help thanks
The pluto-for-channels project does not offer any support for Stirr.
Ahhh so you are correct my bad .. still same question though for others and thank you Maddox. Appreciate your supprt
I’m afraid I gave up on Stirr myself, since all I could find were public M3us (which didn’t work well). Are you using a techzyon link?
I found this one
https://i.mjh.nz/Stirr/playlist.m3u8
and guide
https://i.mjh.nz/Stirr/epg.xml
to be somewhat better.
yes I am
I will check it out thanks
