Streaming issues on mycloud duo
I am using a mycloud home duo and everything had been working fine. The last few days no streaming outside of the network. It just buffers and eventually will get runner unavailable. If I try to stream a recording it just keeps buffering. When this happens I have the same thing happen in the home. If I reboot the server everything works great until I try to steam outside of my network. I have t got any new equipment or changed any settings.
Thanks
What kind of HDHomeRun are you recording from?
Are you streaming from the Channels app or web UI?
I am using the Quattro and channel app
I was able to reproduce this issue. We are working on a fix.
Ok thanks
A fix is available in the latest DVR pre-release. To update, see Frequently Asked Questions
Is this beta stable enough to be using as my main DVR
Yes
Thanks I did the beta update and seems to have solved my problem
