What firmware version are you running? Check http://my.hdhomerun.com for any updates
Usually HDHR devices are very stable and shouldn’t need a reboot. If you’re having issues you may want to work with [email protected] so they can get to the bottom of it and fix it in a firmware update. The original stock firmware on the new CONNECTs had some issues but they should all be resolved now afaik.
