Streaming rate
anyone know why the streaming rate is so low? local channel broadcasting in atsc3.
below is from tuner status.
|Modulation Lock|atsc3|
|Signal Strength|97%|
|Signal Quality|88%|
|Symbol Quality|100%|
|Streaming Rate|4.980 Mbps|
|Resource Lock|192.168.1.6|
ATSC3 uses higher compression
anyway to tell that channel is in 4k?
No stations are in 4k yet, and not for a long long time
thanks you.
