Switching between multiple At Home DVR servers
I like the fact the iOS app now saves and remembers the DVR IP addresses you connect to.
My only issue is it doesn't remember the port number.
Using iOS Beta 5.25.132
My DVR's are at;
192.168.1.3:8089
192.168.1.3:8189
192.168.1.4:8089
192.168.1.4:8189
I can connect to and save 192.168.1.4:8089, then connect to and save 192.168.1.4:8189 by entering the IP:Port.
When I try to reconnect to the last one used (192.168.1.4:8189) it instead goes to 192.168.1.4:8089.
I then manually enter 192.168.1.4:8189 and save it but every time I select to connect to the saved entry (it just displays IP 192.168.1.4 and no port) it connects to 192.168.1.4:8089 instead.
Same issue with 192.168.1.3:8089 and 192.168.1.3:8189
It does work great when using Tailscale since we don't enter port numbers for the Tailnet IP addresses.
Good catch will fix
Tailscale is amazing!
Try new beta
Works great!
Figures that I have 4 servers and it only remembers the last 3. But it does remember custom ports.
I love this new feature. Fantastic.
I wish we could also switch between one At Home server and one Remote server without having to authorize the app for the remote connection every time you switch...
You can if you use the integrated Tailscale feature for remote access.
You would switch to the remote server by choosing Connect At Home and using its Tailnet IP address (like 100.101.102.103).
And that Tailnet IP address can be entered and saved on the client.
Thanks. Will I loose speed in the connection to the remote server if it goes through the Tailscale VPN?
You wont know until you try it. Every setup is unique.
Here's the Tailscale topic thread
Ive noticed a repeatable client crash on both android (on my firestick) and ios, tvos of the beta apps using this feature. On firestick without this new feature - with a manual input of the address change.
It happens after you switch at home ip addresses, doesn’t necessarily have to be tailscale ips.
After switching servers, the first play of any station, the app crashes.
Very consistently the next time you run the client app and play the station and others works fine.
Seems to be after the first switch of ip addresses.
I did send a crash debug info from my ipad yesterday when i noticed it.
And just submitted diagnotics from the apple tv
