Synology keeps stopping Channing DVR from running
This just started this morning. I noticed nothing is being recorded and I can't log into Channels DVR. I checked my Synology NAS Package Center and I find out that Channels DVR is not running. I hit the run butting and everything starts to work for a minute or so, then it all stops again. I go back to my NAS and I notice that it's not running anymore. It keeps stopping Channels DVR from running.
The synology did the same thing to me while I was scanning TVE. I'm on the latest pre-release.
I started the server back up on DSM and all is good.
DSM 7 has en update. I installed the updated and the process restarted channels and all my docker containers.
Can you check the logs?
/volume1/@appstore/ChannelsDVR/channels-dvr/data/channels-dvr.log
I’ll look this up but I did update to the latest DSM last night. Can’t help but think that had something to do with it.
Upgraded yesterday to latest DSM and upgrade channels a couple of times yesterday and today and all is working fine.
I’m trying to get to the log file but apparently those folders are hidden. Is there a workaround to get to it?
I use WinSCP (Windows PC) to get into mine - enable SSH on the Synology
Same issue on my machine. Seems to be working randomly now though. Here's what I saw in the log file.
2023/04/20 20:07:10.576976 [SYS] Starting Channels DVR v2023.01.23.1746 (linux-x86_64 pid:31405) in /var/packages/ChannelsDVR/target/channels-dvr/data
2023/04/20 20:07:10.748818 [SYS] Started HTTP Server on 8089
2023/04/20 20:07:11.241690 [HDR] Found 2 devices
2023/04/20 20:07:15.661662 [TVE] action=error_response type=Other error=net::ERR_UNKNOWN_URL_SCHEME url=
2023/04/20 20:07:15.663696 [TVE] action=version product=Chrome/89.0.4389.114 jsVersion=8.9.255.24 protocol=1.3 revision=@1ea76e193b4fadb723bfea2a19a66c93a1bc0ca6
2023/04/20 20:07:15.718426 [TVE] action=mock
2023/04/20 20:07:15.724003 [TVE] action=navigate url=https://www.foxsports.com/live
2023/04/20 20:07:15.724938 [TVE] action=request type=Document method=GET url=https://www.foxsports.com/live
2023/04/20 20:07:15.724955 [TVE] action=auth_domain domain=www.foxsports.com
2023/04/20 20:07:15.724960 [TVE] action=foxsportsauth step=start
2023/04/20 20:07:15.814688 [TVE] action=wait_for_page
2023/04/20 20:07:20.320916 [TVE] action=error_response type=Media error=net::ERR_ABORTED url=https://cdn.taboola.com/libtrc/static/video/t_PERFORMANCE_VIDEO_OPTIMIZATION_1/h_400,c_scale/v1680790776/hm588rsxq31ekcqf8k1z.mp4
2023/04/20 20:07:20.517686 [TVE] action=exception err=&runtime.ExceptionDetails{ExceptionID:1, Text:"Uncaught (in promise)", LineNumber:0, ColumnNumber:0, ScriptID:"1", URL:"https://www.foxsports.com/live", StackTrace:(*runtime.StackTrace)(nil), Exception:(*runtime.RemoteObject)(0xc000895440), ExecutionContextID:2, ExceptionMetaData:easyjson.RawMessage(nil)} value=DOMException: Failed to load because no supported source was found.
2023/04/20 20:07:20.670436 [TVE] action=exception err=&runtime.ExceptionDetails{ExceptionID:2, Text:"Uncaught (in promise)", LineNumber:0, ColumnNumber:0, ScriptID:"1", URL:"https://www.foxsports.com/live", StackTrace:(*runtime.StackTrace)(nil), Exception:(*runtime.RemoteObject)(0xc0008958c0), ExecutionContextID:2, ExceptionMetaData:easyjson.RawMessage(nil)} value=DOMException: Failed to load because no supported source was found.
2023/04/20 20:07:20.670654 [TVE] action=error_response type=Media error=net::ERR_ABORTED url=https://cdn.taboola.com/libtrc/static/video/t_PERFORMANCE_VIDEO_OPTIMIZATION_1/h_400,c_scale/v1680790776/hm588rsxq31ekcqf8k1z.mp4
panic: runtime error: invalid memory address or nil pointer dereference
[signal SIGSEGV: segmentation violation code=0x1 addr=0x60 pc=0x62b4b4]
goroutine 100 [running]:
net/url.(*URL).Query(0xc0009e1540?)
	net/url/url.go:1115 +0x14
github.com/fancybits/channels-server/tve.(*authState).eventListener(0xc0007f85a0, {0x19643c0?, 0xc000814b40?})
	github.com/fancybits/channels-server/tve/auth.go:1291 +0xe14
github.com/chromedp/chromedp.runListeners({0xc00088f860?, 0xc0005b3f10?, 0x1ed082e?}, {0x19643c0, 0xc000814b40})
	github.com/chromedp/[email protected]/util.go:84 +0x19f
github.com/chromedp/chromedp.(*Target).run.func1()
	github.com/chromedp/[email protected]/target.go:130 +0x2c5
created by github.com/chromedp/chromedp.(*Target).run
	github.com/chromedp/[email protected]/target.go:105 +0xda
Both are older versions
Follow steps 3 and 4 to update
