My Tablo link is acting up it giving me this error invalid source url: failed to retrieve m3u: 503 Service Unavailable
Any Suggestions?
Any Suggestions?
Check to make sure your Tablo didn't change IP addresses.
Thanks just check IP address is right still not working
Reboot your Channels server.
Thanks MikeBear Tablo is up and running
Did the reboot fix it?
Yes
Getting a new error my Tablo is not loading below is the error; It was working fine until today
Sounds like the docker isn't running
Thanks
Got Tablo running thru Docker, unfortunately, I can not get a guide so I can record tv programs, I have enclosed screenshots of my setup, how can I fix this.
Try Guide Maintenance > Refresh
Thank You
that solve the issue
I have a new issue on Tablo I get reconnecting how do I fix that since I can not connect to any channel?
Is the tablo docker running on the same imac as the DVR?
If not you should use the IP not localhost
Yes same iMac for the Docker and DVR.
I remove the Docker for Tablo and replaced a new one now I can not get Tablo this is the message I get when putting it in Custom Channels.
Got Tablo Back in Sources unfortunately, I getting on web Browser Reconnecting message and on The TV app I get this message Playback Failed (17), how do I fix it?
Check the docker logs to see if there is some error
Does the regular Tablo app let you watch?
