Tablo for Channels
Thanks for replying the Tablo App works I don't see any log for Tablo in Docker only MLB
After seeing that error on the TV, click Settings > Support > Submit Diagnostics on the app
I Summit Diagnostics on the app to Support just now.
Edit the M3U source and make sure Type is set to HLS (not MPEG-TS)
Thank You very much it works great! :grinning:
Tablo hardware can now be integrated directly without docker.
Works like a charm! Thank you.
Thank You very much
This is a KEY diversification point, and a great future-proofing step. Well done (even though I'm 100% SiliconDust)
