I have two homes running Channels DVR, both are running Tailscale. I’m attempting to switch between a local DVR and a Remote DVR. I'm logged into the AppleTV with the same account, maybe this has something to do with my issues..?
I delete all AppleTV Channels Apps and install the beta.
I first have to connect to my local dvr in order to get to settings to turn on Tailscale. I’m not sure how I’d turn on Tailscale if I was away from home without a DVR to setup. I use the local IP and it connects.
After I connect to my local DVR, I set up Tailscale, and switch the connect to the remote Tailscale IP. The setup screen shows the remote Tailscale ip but when I switch to the guide I still see the local DVR channels.
Exit Channels and come back in it presents the setup screen “Learn More”, “Connect”, “Help”. At that point I can’t select any of the buttons and I need to quit Channels.
Restarting Channels I get the setup screen. I enter the Tailscale remote ip again, it shows on the setup screen, but the guide is still my local dvr.
No matter what I do I Channels forgets the ip and I have to set it up each time I start Channels. If I leave channels with the initial local ip then it remembers the ip.
Can there be an easier way to switch between DVRs? I know most people only have a single DVR but it sure would make it easier.
