Did you just update the DVR server in the last 15mins? I was doing testing and had the same results and couldn’t get video to play in the browser and then the server restarted on its own and browser playback is working, HW transcoding enabled itself again, and pausing in the app is much less frequent.
Using Https, pausing didn’t help a little while ago but did the last few times i tired, after the server updated?
This is all I could get, the web view deleted my logs when the server restarted, mayeb I can get those through powershell?
2017/10/06 21:40:04 [HLS] Starting transcoder for channel 1129 (encoder=h264_nvenc, resolution=720, deinterlacer=blend, bitrate=4000)
2017/10/06 21:40:46 [HLS] Stopping transcoder session ANY-ch1129 @ 41.341845s
2017/10/06 21:40:46 [TNR] Closed connection to 131F8367 for ch1129
[mpegts @ 00000000025ab720] Dropped corrupted packet (stream = 2)
[mpeg2video @ 0000000002eb0b80] invalid cbp -1 at 95 30
[mpeg2video @ 0000000002eb0b80] Warning MVs not available
2017/10/06 21:40:54 [sessions] ERROR! securecookie: the value is not valid
2017/10/06 21:41:07 [sessions] ERROR! securecookie: the value is not valid
2017/10/06 21:41:28 [sessions] ERROR! securecookie: the value is not valid
2017/10/06 21:41:50 [TNR] Opened connection to 131F8367 for ch1129
2017/10/06 21:41:50 [HLS] Starting transcoder for channel 1129 (encoder=h264_nvenc, resolution=720, deinterlacer=blend, bitrate=4000)
2017/10/06 21:42:28 [HLS] Stopping transcoder session ANY-ch1129 @ 36.557277s
2017/10/06 21:42:28 [TNR] Closed connection to 131F8367 for ch1129
[mpegts @ 00000000025cb720] Dropped corrupted packet (stream = 2)
[mpeg2video @ 00000000025dd220] Invalid mb type in B-frame at 66 23
[mpeg2video @ 00000000025dd220] Warning MVs not available
2017/10/06 21:43:00 [TNR] Opened connection to 131F8367 for ch1129
2017/10/06 21:43:00 [HLS] Starting transcoder for channel 1129 (encoder=h264_nvenc, resolution=720, deinterlacer=blend, bitrate=4000)
2017/10/06 21:44:51 [HLS] Stopping transcoder session ANY-ch1129 @ 1m48.736s
2017/10/06 21:44:51 [TNR] Closed connection to 131F8367 for ch1129
[mpegts @ 000000000251b720] Dropped corrupted packet (stream = 2)
[mpeg2video @ 000000000307fb40] ac-tex damaged at 29 0
[mpeg2video @ 000000000307fb40] Warning MVs not available
