So, it wouldn't take 192.168.1.0/23 yielding this message:
As the message suggested, I used 192.168.0.0/23 and approved through the Tailscale admin console.
Now, it seems that I must let the Tailscale Subnet know where the LinkPi is located...
My default gateway is what you suggested: 192.168.1.1.
Synology settings:
Router settings:
That worked!
I don't know how I ended up with this conversation becoming a new topic on the forum... I meant to send as a DM.
I'm still in the dark as how to get the LinkPi added to the subnet so that I can access it.
EDIT: Oh, I see! I can just enter the local IP address of the LinkPi as if I was on the LAN.
Boom! I'm in! Thank you so much for the suggestion and help!
It's pretty cool to be able to access devices which cannot run any client software. In particular, I'm able to get to the GUI for my "Keep Connect" router rebooter. I was never able to remotely change the settings on that thing.
So, here's a question... I have a second home where my other Synology Nas serves to provide offsite back up my important files and also hosts a backup of Channels DVR server, in case my primary NAS happens to be come disabled at home. Do I need to set up a second Tailscale subnet at the other location so that I can access the "dumb" devices on the other LAN? Or, do both locations fall under the same subnet?
That's the simplest, easiest way.
Otherwise you would have to setup 4via6 subnet routers at each location (and do a lot of reading).
That makes a lot of sense. Even a dummy like me knew that there could be conflicts between devices which have the same IP addresses on different LANs. Combining both LANs together would result in tons of duplicate ip addresses.
I have tried to muddle through some of the Tailscale documentation. It's a completely incomprehensible language... The easiest way has to be the only way for me.
