Strange behavior happening with my Tivo Streak 4K device, that my mother uses in her bedroom. (it has been months since she has used it and it has had at least 2 OS updates)
When you play a channel, any channel, OTA or TVE, then you back out of the playback, to the guide, and you press the Power button on the remote, to "sleep" the Tivo and turn off the TV, it is like it is pressing the enter/play button, and it thus starts streaming the channel again, even though the TV is off.
When i turn it back on via the remote, Channels is up, the channel is in live playback, but paused, the Progress bar is filled in from the start time i turned it off.
I did a few tests just now, and confirmed this behavior .
Everytime you "sleep" the TiVo when you on on the Guide page, it will launch live playback of that selected channel program. Like is is also pressing Enter or Play.
Does it as well on the On Now page.
I manualy turned on the tv via its own physical pwr button, and the Channel is in fact playing live, so it is the press of the Pwr button on the remote, to turn on the tv, that again send a Enter/Play/Pause command and pauses the live playback.
If i fully back out to the main tivo/android tv home screen, and press the power button, it works fine, and is not clicking to open the Channels app again. Pwr back on and its still on the home screen....so it seems to be something with the Channels app.
I have tried the following things, and had no change.
Disabled Channels DVR Button detector
Disabled the HDMI CEC option in the Settings, More, HDMI CEC settings
(does not appear to even be using CEC, since the TV still turns off and on with this off, also, its and ancient tv, doubt it supports CEC.
No other settings have changed on the TiVo for many months.
Only has its OS been updated at least 2x, and the Channels beta app updated.
Channels app version 101.20.14
i submitted diags via the app for video player and other a couple times.
(also, at least twice, of it sitting not in use for a while, when we try to play a channel, it is fully stutter, unwatchable, micro stutters of half a second, and the audio is as such. i notice it is the whole system, even the system sounds in the menu, or the YT app. Physical power cycle only thing that fixes it....but that may be unrelated issue and I still need to see if that keeps happening)
