I submitted diagnostics from this morning. I was able to view from iPhone on prod app, but not beta app.
It seems to work when I use the connect channels DVR Server and use away from home. I guess that's why you see the external IP.
Still not working on local network for TVE. OTA is still working.
Sent the System Network info via private message.
Here's what the log had for prod app. Took a couple of tries before the stream worked.
2020/03/24 08:33:34.545617 [TVE] stream timestamps: espn1: start_at=2020-03-24T08:33:34-04:00 current_at=2020-03-24T08:33:34-04:00 end_at=2020-03-24T08:34:02-04:00
2020/03/24 08:33:34.547499 [TNR] Opened connection to TVE-ATTOTT for ch6140 ESPN1
2020/03/24 08:33:34.559308 [HLS] Starting transcoder for channel 6140 from 73.54.xxx.xxx (encoder=remux, resolution=, deinterlacer=, bitrate=0)
2020/03/24 08:33:37.684405 [HLS] Probe failed for live stream after 3.123273772s and 0 bytes
2020/03/24 08:33:40.904794 [HLS] Session ch6140-dANY-23278ccdc69d started in 7.976190692s
2020/03/24 08:33:40.905736 [HLS] Couldn't generate master playlist for ch6140-dANY-23278ccdc69d: Could not determine video format
2020/03/24 08:33:40.906119 [HLS] Stopping transcoder session ch6140-dANY-23278ccdc69d (out: 0s, finished: false)
2020/03/24 08:33:40.969788 [TNR] Closed connection to TVE-ATTOTT for ch6140 ESPN1
2020/03/24 08:33:55.245460 [TVE] stream timestamps: espn1: start_at=2020-03-24T08:33:55-04:00 current_at=2020-03-24T08:33:55-04:00 end_at=2020-03-24T08:34:23-04:00
2020/03/24 08:33:55.245567 [TNR] Opened connection to TVE-ATTOTT for ch6140 ESPN1
2020/03/24 08:33:55.262973 [HLS] Starting transcoder for channel 6140 from 73.54.xxx.xxx (encoder=remux, resolution=, deinterlacer=, bitrate=0)
2020/03/24 08:33:58.306398 [HLS] Probe failed for live stream after 3.043003453s and 0 bytes
2020/03/24 08:34:00.948643 [HLS] Session ch6140-dANY-23278ccdc69d started in 5.90254389s
2020/03/24 08:34:00.949137 [HLS] Couldn't generate master playlist for ch6140-dANY-23278ccdc69d: Could not determine video format
2020/03/24 08:34:00.949165 [HLS] Stopping transcoder session ch6140-dANY-23278ccdc69d (out: 0s, finished: false)
2020/03/24 08:34:00.984615 [TNR] Closed connection to TVE-ATTOTT for ch6140 ESPN1
2020/03/24 08:34:17.911296 [TVE] stream timestamps: espn1: start_at=2020-03-24T08:34:17-04:00 current_at=2020-03-24T08:34:17-04:00 end_at=2020-03-24T08:34:46-04:00
2020/03/24 08:34:17.912459 [TNR] Opened connection to TVE-ATTOTT for ch6140 ESPN1
2020/03/24 08:34:17.922333 [HLS] Starting transcoder for channel 6140 from 73.54.xxx.xxx (encoder=remux, resolution=, deinterlacer=, bitrate=0)
2020/03/24 08:34:18.263181 [HLS] Probed live stream in 340.185624ms: h264 1280x720 progressive 6078393bps
2020/03/24 08:34:18.353760 [HLS] Session ch6140-dANY-23278ccdc69d started in 642.088266ms
2020/03/24 08:34:18.372180 [ENC] Starting encoder for ch6140 in /Volumes/ChannelsDVR/recordings/Streaming/ch6140-dANY-23278ccdc69d-510655158/encoder-1-651571274 at 1 (0.013667) (encoder=h264_videotoolbox, resolution=720, deinterlacer=linear, bitrate=3000 segment_size=0.01)
2020/03/24 08:34:28.453305 [HLS] Stopping transcoder session ch6140-dANY-23278ccdc69d (out: 32.746367s, finished: false)
2020/03/24 08:34:28.465727 [ENC] Stopped encoder for ch6140 in /Volumes/ChannelsDVR/recordings/Streaming/ch6140-dANY-23278ccdc69d-510655158/encoder-1-651571274 after encoding 1 to 15
2020/03/24 08:34:28.491304 [TNR] Closed connection to TVE-ATTOTT for ch6140 ESPN1
2020/03/24 08:34:29.128438 [TVE] stream timestamps: espn1: start_at=2020-03-24T08:34:29-04:00 current_at=2020-03-24T08:34:29-04:00 end_at=2020-03-24T08:34:57-04:00
2020/03/24 08:34:29.128578 [TNR] Opened connection to TVE-ATTOTT for ch6140 ESPN1
2020/03/24 08:34:29.140984 [HLS] Starting transcoder for channel 6140 from 73.54.xxx.xxx (encoder=remux, resolution=, deinterlacer=, bitrate=0)
2020/03/24 08:34:32.274371 [HLS] Probe failed for live stream after 3.132900214s and 0 bytes
2020/03/24 08:34:40.086817 [HLS] Session ch6140-dANY-23278ccdc69d started in 11.52331896s
2020/03/24 08:35:00.146995 [HLS] Stopping inactive session ch6140-dANY-23278ccdc69d
2020/03/24 08:35:00.149117 [HLS] Stopping transcoder session ch6140-dANY-23278ccdc69d (out: 57.344s, finished: false)
2020/03/24 08:35:00.182198 [TNR] Closed connection to TVE-ATTOTT for ch6140 ESPN1
