Tuner not available, server is idle
You mean on your Channels DVR server?
What are you running it on?
What Channels app are you using on it?
So you mean you are remote desktop and opening a browser on the server? What is your web player transcode set to? Did you try reducing that?
start with the web player settings at 720p @ 4mbps, and reduce from there if needed.
1080p @ 6mbps
ISP allows for 20 mbps upload which shouldn’t apply in this case because this instance is on the local network. Should be able to run original with no problems.
but you are RDP'd in which is all getting transcoded again. I don't know if team player is good for that. What happens if you play youtube through the remote desktop on the browser? Does it work?
240p @ 360kps doesn’t work either on the local network server client.
does youtube video work? If thats the same, then I think viewing the video over remote desktop is not a way to tell what the problem is with your remote apple tv network connection.
I can view it through silicon dust while teamviewered in. Not the best for video but can see it’s working.
@tmm1 does this help at all?
It still is recording properly but can’t view live tv.
Actually when I try to record a random show right now, it doesn’t record and the server says it’s delayed
I can also view live tv with the silicon dust app with other local network (same as the dvr) machines. Might be a channels issue?
I don't know, but I would say stop. Use the software as intended. How would anyone be able to tell where the problem is in this case? Remote desktop software adds a layer of complexity that would just create guessing by anyone.
Remote Desktop is fine and isn’t the problem. I’ve been using it for years. This problem still exists though. Any word on fixing or more troubleshooting? @tmm1
Edit: Remote Desktop is used for troubleshooting not actual viewing
Did you submit diagnostics after upgrading to prerelease?
Try rebooting the hdhomerun? Or changing priority to use a different one?
If you record and try to watch the mpg file does it play video?
I’ll submit right now. I’m on the local network right now physically. I’ll send from an Apple TV and the server. 31957f7d-9f01-4ce0-9a39-2efe24fce039
I tried rebooting and changing priorities with no luck.
It does play already recorded content with no problems and seems to still record scheduled shows. Just no live tv.
Does Channels app play live TV at home? With streaming quality original
No. It plays through on Hd home run software on a iMac and my phone when on the local network.
Does it play in the hdhomerun appletv app?
Yes. May be slightly jittery if I pay real close attention but nothing dramatic.
