If you keep removing and readding your account you will start to hit rate limits. You should use the pencil icon and edit button to re-scan specific channels. You can also see the full list of supported channels under the edit menu.
If there are specific channels that are missing we may be able to add them if you follow the guidelines in the TVE FAQ:
