Hello my extraordinary Channel Community,
It might be an odd question, do we somewhere on the website have a list of the TV Guide Abbreviations i.e. what are the call letters to add a channel to the TV Guide lineup? Some channels for the life of me I just can't find when I am searching for (and I am talking about networks in the U.S. & Uk I am sure are on there), while switching to search all lineups.
Thank you for your kind guidance.
Are you trying to map guide data to channels you have?
What is the source, an HDHR tuner?
it's a Channels Tuner (on a blackberry) and those are channels I have added from a custom channels source (m3u8)
Not sure what that means
You have to find an appropriate callsign or gracenote stationid for the channel.
As far as I know, nobody has spent their time looking them all up for you. I'm sure if they have, they'll post or DM you.
Here's what I do when I need to get guide info for a channel that has none, or is incorrect.
You will need to invest some time using this method.
Hey there! Great question—it's not odd at all! Unfortunately, I don't think there's a dedicated list of call letters on the website for the TV Guide lineup. However, I’ve had a similar issue with finding certain channels, especially from the U.S. and the UK. Sometimes the channel names aren’t exactly what you expect, so trying different variations or even searching through the full lineup can help. If you're still having trouble, it might be a good idea to reach out to support directly—they're usually super helpful with these kinds of things!
Streamlink Manager has a search function now that shows callstation IDs if anyone looking for a solution to this.
OliveTin for Channels can provide this OliveTin for Channels: An Interface for Misc Channels DVR Scripts & Tricks - #7 by chDVRuser
Based on my Windows script Search for Gracenote Station ID's
Or you can search using your browser using double quotes to enclose a phrase to search for
http://127.0.0.1:8089/tms/stations/"bbc news north america"
which is url encoded as http://127.0.0.1:8089/tms/stations/%22bbc%20news%20north%20america%22
Also based on your original code
Just with a number of tweaks for ease of use and the distinctive Streaming Library Manager visual flair!
