What I meant was the .mpg files are not Program Streams, but Transport Streams.
Converting the MPEG2 Transport Streams recorded by Channels DVR to MPEG4 Program Streams by remuxing may not work for playback with Channels clients.
I'm not 100% sure, but I think Channels DVR expects its recording files to be in the MPEG2 Transport Stream container it saved them in, even though the file extension is .mpg.
You could just remux the files with
ffmpeg -i "filename.mpg" -c copy "filename.ts"
This should make the Video stream 0 and add a PCR to that stream.
one of mine for example
Input #0, mpegts, from 'SportsCenter 2020-10-27-2008.mpg':
Duration: 00:30:05.11, start: 0.016689, bitrate: 5492 kb/s
Program 1
Stream #0:0[0x101]: Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 124 kb/s
Stream #0:1[0x102]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, progressive), 1280x720, 60 fps, 59.94 tbr, 90k tbn, 120 tbc
Stream #0:2[0x103]: Data: timed_id3 (ID3 / 0x20334449)
Output #0, mpegts, to 'SportsCenter 2020-10-27-2008.ts':
Metadata:
encoder : Lavf58.20.100
Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, progressive), 1280x720, q=2-31, 60 fps, 59.94 tbr, 90k tbn, 90k tbc
Stream #0:1: Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 124 kb/s
Stream mapping:
Stream #0:1 -> #0:0 (copy)
Stream #0:0 -> #0:1 (copy)
Try it with one of your problem files.
If that works you could delete your original recording "filename.mpg" and rename the newly remuxed file from "filename.ts" to "filename.mpg"
