My setup is probably not the norm. But it works OK in most other DVR apps.
I have two separate antennas located in my attic pointed in two different directions. I get part of my channels from about 40 miles away in one direction and 7 to 10 miles in another direction. No multi directional antenna ever worked for me. Each antenna has a dedicated hdhomerun. Each hdhomerun has different channels enabled so that I am only tuning the channels in the proper direction. This way I don’t get any recordings taking place on the weak signal channels from the antenna not pointing in the right direction.
However, in the web app my guide only shows one of the tuners. I have both of the tuners set up with the same guide data (local OTA) and have favorited the correct channels on each tuner. Is combining tuners this way into one guide supported?
